Td5 centre console removal
You need to take the top dash panel off - so the screws either end of the vents, a couple of small screws up into the panel from the top edges of the recesses in the front of it, the 3(?) big screws through the top of the panel - and both end pieces (handle and vent controls).
Once that's out it will reveal a couple more screws on the top of the dash panel.
You can just about use one of those stubby screw drivers.
An alternative might be that if you have the tools to pull out the radio - you could possibly get your hand in and push the switch out from behind ?
The cage may stop that though - and it's not a big job to pull out the top of the dash.
Only other bit I didn't mention before was on the left hand side grab handle their is a screw at the bottom going in downwards - and a second behind the little Land Rover badge, which you can prise out with a small screwdriver.
My halfords ratchet spanner set cane with an attachment which takes a normal hex screw driver bit, and then has a 10mm hex on the back of it.
For when I have needed to get in very tight places to get to a screw it has been very good, and really only as deep as the bit in the holder.
