Nigelw Posted April 3, 2016 Share Posted April 3, 2016 Anyone know if the top mounting bracket is the same front and rear on QT diff guards? Like this one. Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2016 Share Posted April 3, 2016 might help http://www.qtservices.co.uk/parts/land-rover-defender-110/protection-defender-110/diff-guard-defender-110/1/ Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2016 Share Posted April 4, 2016 From memory they were both the same on mine. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 4, 2016 Author Share Posted April 4, 2016 might help http://www.qtservices.co.uk/parts/land-rover-defender-110/protection-defender-110/diff-guard-defender-110/1/ Ralph, what did you just do Click linky, start browsing the diff guards and suddenly get nauseous at the mention that these things are "handed" after tea I'm off to check! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2016 Share Posted April 4, 2016 By handed you mean different front and rear? The only difference is that the front one has to clear the track rod so doesn't have the slider part under the diff that the rear one has. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 4, 2016 Author Share Posted April 4, 2016 No Ross, handed as in LHD & RHD version Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2016 Share Posted April 4, 2016 But the axle case isn't any different? Wonder if it's a clearance issue then!? Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 4, 2016 Author Share Posted April 4, 2016 Been out and loosely held it up against the diff, don't look like it fouls the PH rod but clearance would be tight either RHD or LHD. Coincidentally, anyone know if pan hard rod mounting differs between LH & RH drive vehicles? Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2016 Share Posted April 4, 2016 Ralph, what did you just do Click linky, start browsing the diff guards and suddenly get nauseous at the mention that these things are "handed" after tea I'm off to check! just giving you some info, I didn't actually read the link, just thought going to makers website would help get a answer, sorry if you've had a shock finding out there are left & right hand drive variants. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 4, 2016 Author Share Posted April 4, 2016 just giving you some info, I didn't actually read the link, just thought going to makers website would help get a answer, sorry if you've had a shock finding out there are left & right hand drive variants.It's ok, was beginning to think my supposed bargains were not so great after all, the flexy on the snorkel being perforated and the top bracket missing off the rear.Oh well, goin to the yard early to knock up a second bracket before work. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2016 Share Posted April 4, 2016 Mine used to just rub the panhard a slight touch on one edge. Panhard is fitted opposite way round on a LHD. Chassis end is always closest to the steering box. Quote Link to comment Share on other sites More sharing options...
Lewis Posted April 4, 2016 Share Posted April 4, 2016 Personally I'd forget that bracket and just weld it to the top of the axle case; when I used QT guards they would always twist to the side with a good knock, welding cured that Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2016 Share Posted April 4, 2016 I like Lewis' idea. But clean it out regularly as mine used to like filling up (when the car was used ) Quote Link to comment Share on other sites More sharing options...
Nigelw Posted April 5, 2016 Author Share Posted April 5, 2016 Personally I'd forget that bracket and just weld it to the top of the axle case; when I used QT guards they would always twist to the side with a good knock, welding cured that Top tip! Gonna wire wheel and epoxy paint the diff cover and once painted I'll do as you suggest Lewis.Ross, to PH rod attaches just to the left(looking at the axle from the front of the vehicle) of the diff so the bulge is axle end of the rod. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 5, 2016 Share Posted April 5, 2016 Yeah so the rod on. RHD has the bulge at the chassis end of the rod Quote Link to comment Share on other sites More sharing options...
