gsr341 Posted November 23, 2006 Share Posted November 23, 2006 has any one tryed or has a source for 12v pnematic solinoid valves , have recently bought an ARB rear doiff lock and will shortly be plumbing it in , but the ARB solinoids are around £55 there has to be a better/cheaper solution ? any one using any thing exept ARB solinoids for this job ? Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 23, 2006 Share Posted November 23, 2006 where abouts do you live? I got manual ones for mine from Hyphose (sp?) Quote Link to comment Share on other sites More sharing options...
gsr341 Posted November 23, 2006 Author Share Posted November 23, 2006 where abouts do you live? im in north wales , have updated my profile , will cheak the stores in work , then off to either blackwell hydralics , or BSL cheers no problems with them ?how much where they ? Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 23, 2006 Share Posted November 23, 2006 Try Trailer Spares (dont know the web address) or pop in to your local HGV mechanics, they should be able to help you out - my mate got one for his Air horn from his work (truck mechanic) Lewis Quote Link to comment Share on other sites More sharing options...
Bush65 Posted November 24, 2006 Share Posted November 24, 2006 has any one tryed or has a source for 12v pnematic solinoid valves , have recently bought an ARB rear doiff lock and will shortly be plumbing it in , but the ARB solinoids are around £55 there has to be a better/cheaper solution ? any one using any thing exept ARB solinoids for this job ? I don't like the ARB switches, they are prone to failure. I have changed to manual operated pneumatic valves and would never go back to solenoid operated valves. I use SMC 2 position, 3 way, valves, but there are many other manufacturers. Fit the valve where you would fit the switch for a solenoid valve, and run pneumatic tubing instead of electrical wiring. Quote Link to comment Share on other sites More sharing options...
simonr Posted November 24, 2006 Share Posted November 24, 2006 There's something more satisfying about a manual pneumatic valve too! Si Quote Link to comment Share on other sites More sharing options...
