PeterW Posted November 24, 2006 Share Posted November 24, 2006 Quickie... I'm in Ipswich and my wheels are in Nottingham and I need a dimension... Anyone know how wide the old steel Rostyle RR Rims are...? I've got a decent offer on some new steels, and want to check if my 7.50's will fit... Cheers Pete Quote Link to comment Share on other sites More sharing options...
samwilk200 Posted November 24, 2006 Share Posted November 24, 2006 Quickie...I'm in Ipswich and my wheels are in Nottingham and I need a dimension... Anyone know how wide the old steel Rostyle RR Rims are...? I've got a decent offer on some new steels, and want to check if my 7.50's will fit... Cheers Pete No problem fitting those tyres, i have 235/85 on mine and there perfect!! I'm fairly sure you could fit up to a 265 on them without problems. Quote Link to comment Share on other sites More sharing options...
PeterW Posted November 24, 2006 Author Share Posted November 24, 2006 No problem fitting those tyres, i have 235/85 on mine and there perfect!! I'm fairly sure you could fit up to a 265 on them without problems. I'm actually looking at old tyres on new rims... so I need to know if a 7.50/16 will fit on a wheel like this... Here..... Cheers Peter Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 24, 2006 Share Posted November 24, 2006 So you want to fit 7.50's to 7" rims. I had 7.50's on a set of steel disco rims which are 7x16, mine were fitted with tubes and were fine. However 7.50's would be better on a 6" ish rim. I think rostyles are 6.5" but am not sure. Quote Link to comment Share on other sites More sharing options...
PeterW Posted November 24, 2006 Author Share Posted November 24, 2006 So you want to fit 7.50's to 7" rims. I had 7.50's on a set of steel disco rims which are 7x16, mine were fitted with tubes and were fine. However 7.50's would be better on a 6" ish rim. I think rostyles are 6.5" but am not sure. Mark thats right...! My 7.50s still have some life left in them, so I might as well use them. Its just the rims are shot (warped..) and I need to do something FInding 6.5x16 aftermarket steels is not easy ! Cheers Peter Quote Link to comment Share on other sites More sharing options...
samwilk200 Posted November 24, 2006 Share Posted November 24, 2006 Mark thats right...!My 7.50s still have some life left in them, so I might as well use them. Its just the rims are shot (warped..) and I need to do something FInding 6.5x16 aftermarket steels is not easy ! Cheers Peter They will fit fine on a 7" wide steel rim. Quote Link to comment Share on other sites More sharing options...
Lars L Posted November 24, 2006 Share Posted November 24, 2006 Rostyles are 6"... And aftermarket Wolf wheels are 6,5". Quote Link to comment Share on other sites More sharing options...
missingsid Posted November 24, 2006 Share Posted November 24, 2006 Rostyles are 6"... And aftermarket Wolf wheels are 6,5". The link went to a Modular wheel, these are NOT Land Rover OEM wheels and will be the size the manufacturer chose to make them. I think you are right that RR steels are 6 inch I will have the tyres removed from mine tomorrow as I need to fit 7.50 16 to them temporaaily. I have a feeling you are not supposed to fit them though? I have seen Simex fitted to RR steels, Idon't know if they have been widened or not. I have had a set of 7.50 16 tyres on LWB rims widened to 8 inch rims for the last 20 or so years with no problems but that was my choice and this is not to be taken as a recommendation. I will measure my wheels to check tomorrow. Yup they are. Marc. Quote Link to comment Share on other sites More sharing options...
