mcc1979ian Posted July 10, 2016 Share Posted July 10, 2016 Finally got the fuel banjo iv been waiting on so today got round to fitting it and trying to fire it up. It croaked and for a split second started then immediately shut off again then just cawed and cawed but wouldn't fire. I'm assuming it just burnt off what fuel was in the pipes. The filter is empty so I tried priming it with the lift pump but there's no resistance whatsoever in the pump. Could the pump be at fault? 1 Quote Link to comment Share on other sites More sharing options...
pete3000 Posted July 10, 2016 Share Posted July 10, 2016 don't mess about with lift pump, pull white wire off stop solenoid. Then open 10mm nut on filter and get a helper to crank it over till you get fuel out of the bleed nut. If you don't uou either have no fuel, a blockage or your lift pump is banjaxed. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 12, 2016 Share Posted July 12, 2016 another way is to use a brake vacuum bleeder on the filter vent. i did this to prime mine when the lift pump was stuffed. 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted July 13, 2016 Share Posted July 13, 2016 Much easier and quicker to use engine to prime the fuel system as per pete's suggestion. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted August 13, 2016 Author Share Posted August 13, 2016 Silly mistake. Hadn't tightened the nut holding the cables on the starter 1 Quote Link to comment Share on other sites More sharing options...
western Posted August 13, 2016 Share Posted August 13, 2016 so that's another job successfully knocked off the long list Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted August 13, 2016 Author Share Posted August 13, 2016 The lists gettin better now. Down to a wee bit welding and getting them damn indicators working. Quote Link to comment Share on other sites More sharing options...
