IanT90 Posted July 16, 2016 Share Posted July 16, 2016 I spend most of the time submitting posts moaning or asking for help and support. So for once I wanted to submit a positive bit of advice. Following my recent saga replacing the rear brake disc's,calipers,pads and pipes etc I finally got to the last stage bleeding the system and I dreaded it, having done this many time over the years various way's including easy bleeds. I bought a simple one way valve with two pipes attached. Connect one end to bleed nipple open the bleed nipple. Place container under the other pipe. Next pump the brake pedal I did 6 to 10 to make sure as I couldn't watch for air bubbles. Tighten bleed nipple move to next wheel etc I repeated this a second time topping up the reservoir after each wheel. It worked great easy to use,one man operation wish I had come across this year's ago. Some of you may already be aware of this device but for those who don't and still struggle with the old easy bleed it's worth a change. Cost me less than £5 off ebay great tool :-). Works on clutch system too. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 16, 2016 Share Posted July 16, 2016 i've used every tool in the box, vacuum bleed, easy blead, one man with a pipe, two men ect . the best i've done is with the two man. it would be great if you could post a link to the flee bay item. Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2016 Share Posted July 16, 2016 I use a single pipe with a one way valve on the end IIRC I bought it from local Halfords. similar to this http://www.halfords.com/motoring/engine-oils-fluids/brake-clutch-fluid/europat-vizibleed-bleed-aid never had any problem bleeding my 110's brake or clutch systems or a friends Disco 300. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted July 16, 2016 Author Share Posted July 16, 2016 Bought this while ago but will try and find link Quote Link to comment Share on other sites More sharing options...
western Posted July 16, 2016 Share Posted July 16, 2016 as you bought it off ebay, in your purchases page on there, if it was less than 2 years ago, the item should still be in your purchases links. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted July 16, 2016 Author Share Posted July 16, 2016 Can't set up link as in work and using my phone. However found it on ebay following description: Motorcycle car brake/clutch bleeder bleed one way valve & tube tool kit set. Price - £3.29 free postage Seller - delhanway2009 If still struggling to find it let me know I will use my pc at home tomorrow and attach the link Ian Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 17, 2016 Share Posted July 17, 2016 You can make your own from an old coke bottle, a length of rubber tube with a small slit in it and a screw. Use the screw to block the end of the tube, make a hole in the lid of the bottle and feed the tube through adding enough fluid to cover the slit, the other end goes on the bleed nipple. As you pressurise the the system with the pedal, the slit opens allowing fluid and air out, as you lift off the pedal the slit closes preventing anything being drawn back into the system. HTH Mo 1 Quote Link to comment Share on other sites More sharing options...
qwakers Posted July 17, 2016 Share Posted July 17, 2016 Can't set up link as in work and using my phone. However found it on ebay following description: Motorcycle car brake/clutch bleeder bleed one way valve & tube tool kit set. Price - £3.29 free postage Seller - delhanway2009 If still struggling to find it let me know I will use my pc at home tomorrow and attach the link Ian this one then... http://www.ebay.co.uk/itm/Motorcycle-Car-Brake-Clutch-Bleeder-Bleed-One-Way-Valve-Tube-Tool-Kit-Set-/302004324070?hash=item4650dc46e6:g:qL4AAOSwwo1XegyC Quote Link to comment Share on other sites More sharing options...
IanT90 Posted July 17, 2016 Author Share Posted July 17, 2016 That's the one great little bit of kit thanks, just saved me a job was about to post the link Thanks Ian Quote Link to comment Share on other sites More sharing options...
