orange rover Posted November 28, 2006 Share Posted November 28, 2006 hello, just bought a 90 truck cab. i'm 6' 2" and feel a bit cramped, a bit more legspace would be nice. obviously i can't move the seat any further back. vehicle is a challenge truck, so i was thinking that maybe some bucket seats that have a thinner backrest would do the trick. any suggestions? qt are apparently doing some specially for a truck cab, however not sure wheter they woulld help. cheers orange Quote Link to comment Share on other sites More sharing options...
covedefender Posted November 28, 2006 Share Posted November 28, 2006 Hi I was just looking at seat rails on internet site mudstuff It might be a solution Cheers B) Quote Link to comment Share on other sites More sharing options...
orange rover Posted November 29, 2006 Author Share Posted November 29, 2006 don't think they would make a difference work in a truck cab since the seat is already touching the back of the cab. therefore thought that seats that are thinner may help. cheers orange Hi I was just looking at seat rails on internet site mudstuff It might be a solution Cheers B) Quote Link to comment Share on other sites More sharing options...
michael calvert Posted November 30, 2006 Share Posted November 30, 2006 don't think they would make a difference work in a truck cab since the seat is already touching the back of the cab. therefore thought that seats that are thinner may help.cheers orange buckets will be worse they are fixed vertically, if you need more leg space try a custom seat box as it would lower / raise seat height, also buckets arent very comfy over a long distance believe me i co drive in a rally car!! try a hard tp or extend your truck cab like som ehave one here that way you get more space throughout the cabin and secure place to lock stuf up? Quote Link to comment Share on other sites More sharing options...
gsr341 Posted November 30, 2006 Share Posted November 30, 2006 im 6'1" tall and have bucket seats in my 90 truck cab the only real way of getting any extra leg room (only a small amount mind) is to raise the rear of the seat runners on spacers the problem with the original seats , and after market bucket seats is to be comftable you need the back reclined slightly , but with the combination of the sloping seat box the top of the seat hits the truck cab but by lifting iup the rear of the seat (i lifted mine 40mm) it brings the back of the seat away from the cab allowing you to slide it back it tiny bit more and as they say ''every little helps'' will take some pics of how i done mine if any ones intrusted ? Quote Link to comment Share on other sites More sharing options...
JST Posted November 30, 2006 Share Posted November 30, 2006 yes please whack some pics up if you have them please. Quote Link to comment Share on other sites More sharing options...
orange rover Posted November 30, 2006 Author Share Posted November 30, 2006 the problem with the original seats , and after market bucket seats is to be comftable you need the back reclined slightly , but with the combination of the sloping seat box the top of the seat hits the truck cab but by lifting iup the rear of the seat (i lifted mine 40mm) it brings the back of the seat away from the cab allowing you to slide it back it tiny bit more and as they say ''every little helps'' will take some pics of how i done mine if any ones intrusted ? that sounds like a interesting idea! i had the seats out, and without them there actually is lots of space. i think the seats would need to be lower as well as have thinner backs than the originals. then lifting them a bit in the back in order to be able to move them back should to the job, it doesn't take much. other thing that i noticed is that the brake pedal sticks out quite a bit, if the pedals in general would be a bit more forward, then that should give a lot more leg room. havn't looked into it in detail, not sure whether the pedals coul be moved? cheers orange Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted December 1, 2006 Share Posted December 1, 2006 Just to confirm that the only difference the MUD Rails will make in a truck-cab would be to raise the seat slightly. The truck cab design restricts the seat travel further still, so unfortunately adding the rails won't make any difference to legroom. Kev Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 1, 2006 Share Posted December 1, 2006 Just to confirm that the only difference the MUD Rails will make in a truck-cab would be to raise the seat slightly. The truck cab design restricts the seat travel further still, so unfortunately adding the rails won't make any difference to legroom.Kev I totally agree about the space thing. Driving a friends TC 90 the other day reminded me how cramped the cab is and I'm only 5'10"! I'm building my 90 as a TC + 12" and the differance is unbelievable! Quote Link to comment Share on other sites More sharing options...
gsr341 Posted December 1, 2006 Share Posted December 1, 2006 heres the pics of how ive done mine , sorry they not in any sort of order the other adavantage of lifting the rear of the seat when using bucket seats , is it makes them less ''deep'' so you can acctakky get out of them the drivers seat is mounted on a sub frame ,that i made the lift in to. the passenger seat needs removing from time to time (batterys etc) so i built two sub frames one mounts in the truck permently , using spacers for the lift , the other is bolted to the seat rails and , then bolted in to the truck with (when i get them M8 wing nuts) so no tools needed Quote Link to comment Share on other sites More sharing options...
JST Posted December 1, 2006 Share Posted December 1, 2006 cheers for the photos may employ that idea i reckon, got to be worth a go. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted December 1, 2006 Share Posted December 1, 2006 if you still got standard seats just , stick some spacers under the rear , or just a pack o washers to see if it gives you what you want . it worked for me Quote Link to comment Share on other sites More sharing options...
