reb78 Posted March 13, 2011 Share Posted March 13, 2011 Hi All, I'm trying to get rid of anything on my driveway without the green oval! I have been looking at freelanders and i want to trade my BMW in for one. I was looking at HSE spec TD4 Freelanders and was trying to find one with the lowest possible mileage. However, is mileage a big issue for these? I am looking at a rather nice one that has 69K on the clock - is this just run it? What sort of maximum mileage would you reckon to get out of these engines if well maintained? 1 Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted March 13, 2011 Share Posted March 13, 2011 I have had two TD4s a 52 reg GS manual which did 82K miles (bought at 7K) with no probs (even had original back tyres when I sold it), now on a 04 reg SE auto with 64K miles (bought at 18K) and no probs yet. Had both serviced regularly. They are chain drive so no cambelt to worry about and I get about 35mpg on a long run. Watch out for the fuel burning heater on SE and HSE models I am trying to find a way to switch mine off, it's supposed to come on at start up if temp is below 5C but mine stays on until about 10C. I suppose you know it has the BMW engine Quote Link to comment Share on other sites More sharing options...
gary1968 Posted March 14, 2011 Share Posted March 14, 2011 The engine should be fine, just make sure the VCU is good, at around 70k miles it will probably need replaced or you will end up with IRD and/or diff problems as well. HTH, Gaz Quote Link to comment Share on other sites More sharing options...
Blippie Posted March 14, 2011 Share Posted March 14, 2011 On just approaching 110k on our 2002 TD4 and there are people on www.landyzone.co.UK with TD4s well over 150k. Replaced a rear diff bush at 60k (£15), windscreen wiper linkage at 70k (two cable ties or replacenent part at £70) and fuel pumps last year. Most reliable car we've ever had. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
nickcc Posted March 14, 2011 Share Posted March 14, 2011 Bought a Oct 2005 TD4 auto freestyle with 102,000 miles on the clock a few weeks ago, full dealer service. Over the moon so far after fitting new drums and shoes, EGR bypass, crankcase filter, new discs and pads and full service. Suppose the next job will be replacing the VCU even though both the advised checks showed working OK (tippex on props and weight on front wheel). Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 14, 2011 Author Share Posted March 14, 2011 Thanks. Useful info. So 69K is not that high really! The one i have seen is a 2004 HSE, 69K and is up for £7500 at a car dealer. The price seemed a little high for the age, but it does seem in good condition in HSE spec with a FSH (whatever that means these days!). BUT, there are other TD4s going for ~10K with about 40K on the clock. Is there a quick way to check the VCU on a test drive? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 14, 2011 Share Posted March 14, 2011 Reverse round a corner, dip the clutch half way - if it grinds to a stop instantly, it's seized. You should feel a little resistance but not like someone's put the brakes on. Also - are you talking FL1 or the FL2 here? My 2001 TD4 owes me less than £2k, seems quite a jump to the prices you're talking Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 14, 2011 Author Share Posted March 14, 2011 Reverse round a corner, dip the clutch half way - if it grinds to a stop instantly, it's seized. You should feel a little resistance but not like someone's put the brakes on. Also - are you talking FL1 or the FL2 here? My 2001 TD4 owes me less than £2k, seems quite a jump to the prices you're talking Thanks. Thats useful to know. I am talking about the FL1 facelift model. The prices i mention are what seem to be the going rate on autotrader if i do a search. 10K seems to get a 2005 with 30-45K on the clock - model seems less important. I want to do a px, so was looking at traders rather than private ads. This is the example i was looking at (it is older and a higher mileage than the 10K examples, but also less money): http://www.autotrader.co.uk/classified/advert/201107379730549/sort/priceasc/usedcars/maximum-mileage/up_to_60000_miles/price-to/11000/transmission/manual/fuel-type/diesel/model/freelander/make/land_rover/page/1/postcode/en63he/radius/30?logcode=p#dealerProfileSection Quote Link to comment Share on other sites More sharing options...
LR NUT Posted March 16, 2011 Share Posted March 16, 2011 Reverse round a corner, dip the clutch half way - if it grinds to a stop instantly, it's seized. You should feel a little resistance but not like someone's put the brakes on. Is there any maintenance required for the VCU such as greece to preserve the unit? many thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 17, 2011 Share Posted March 17, 2011 Is there any maintenance required for the VCU such as greece to preserve the unit? No, it's a sealed unit and the bearings are also of the sealed type - a couple of companies will recondition the VCU if it seizes, Bell Engineering did mine and it seems to work well, there's another company who put a less viscous fluid in to make the unit "drag" less but there was a thread on here about one of theirs not working at all however a friend has had one of their units for some time and seems pleased with it. Quote Link to comment Share on other sites More sharing options...
nickcc Posted March 17, 2011 Share Posted March 17, 2011 Thanks. Thats useful to know. I am talking about the FL1 facelift model. The prices i mention are what seem to be the going rate on autotrader if i do a search. 10K seems to get a 2005 with 30-45K on the clock - model seems less important. I want to do a px, so was looking at traders rather than private ads. This is the example i was looking at (it is older and a higher mileage than the 10K examples, but also less money): http://www.autotrader.co.uk/classified/advert/201107379730549/sort/priceasc/usedcars/maximum-mileage/up_to_60000_miles/price-to/11000/transmission/manual/fuel-type/diesel/model/freelander/make/land_rover/page/1/postcode/en63he/radius/30?logcode=p#dealerProfileSection I paid £7795 for a high mileage, 102k, October 2005 FL1 freestyle TD4 auto from a dealer. I also got a far higher part ex price than I could selling privately (MB 2 litre auto estate that no one wanted due to the usual MB rust issues and same road tax cost as my Freelander). Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 17, 2011 Author Share Posted March 17, 2011 I paid £7795 for a high mileage, 102k, October 2005 FL1 freestyle TD4 auto from a dealer. I also got a far higher part ex price than I could selling privately (MB 2 litre auto estate that no one wanted due to the usual MB rust issues and same road tax cost as my Freelander). Thanks. I would say that 7-7500 isnt a bad price for the one in the link given the spec and mileage? I will have a look around the dealers as well, but havent found any in the right price and mileage range there yet. Quote Link to comment Share on other sites More sharing options...
Dorsetfreelander Posted March 18, 2011 Share Posted March 18, 2011 Just put my 04 reg TD4 auto in for MOT with 64K miles and passed with no probs or advisories. Can't complain at that. Just get it serviced every 12K by someone who knows Freelanders. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 18, 2011 Author Share Posted March 18, 2011 Just put my 04 reg TD4 auto in for MOT with 64K miles and passed with no probs or advisories. Can't complain at that. Just get it serviced every 12K by someone who knows Freelanders. Jolly good! Part of the reason i want another land rover is because i'll do all the work on it myself. Technical enough to be a decent vehicle, but not so much that the home mechanic cant touch it (unlike the BMW engine in my 5 series!) so servicing and maintenance will be nice and regular. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 21, 2011 Author Share Posted March 21, 2011 Well. Looked at a few and just put a deposit down on the one i linked to above. All seemed ok on the test drive. VGC outside, a few scrapes on the door handle inside, but generally good condition. So, as of friday, i guess i'll be asking questions on this bit of the fourm as well! Quote Link to comment Share on other sites More sharing options...
nickcc Posted March 22, 2011 Share Posted March 22, 2011 You can sometimes get the silver interior door handle off ebay, about £20, the one on mine is badly scratched but I may take it off and try plastic bumper spray first. Before you pick the car up check the rear cubby hole box for water, my jack was rusted solid, this is usually due to a leaking rear door seal and a modified replacement fitted will cost you about £250 at a LR dealer. I had a new one fitted, before I picked the car up, as part of the deal. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 22, 2011 Author Share Posted March 22, 2011 You can sometimes get the silver interior door handle off ebay, about £20, the one on mine is badly scratched but I may take it off and try plastic bumper spray first. Before you pick the car up check the rear cubby hole box for water, my jack was rusted solid, this is usually due to a leaking rear door seal and a modified replacement fitted will cost you about £250 at a LR dealer. I had a new one fitted, before I picked the car up, as part of the deal. Thanks. I was thinking of taking them off and spraying them (if i can get them off without breaking the clips!). I checked the cubby hole box when i looked over it and it all seemed dry in there. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 25, 2011 Author Share Posted March 25, 2011 Well.....picking it up this evening and am sufficiently nervous about spending my hard earned!! Its always the way that the car you are trading in also runs sweet just before you get rid of it making you think 'is this really the right decision??! - this is such a nice car and i'm getting so little for it!'. I hate buying new vehicles! Quote Link to comment Share on other sites More sharing options...
Chris Sargent Posted March 26, 2011 Share Posted March 26, 2011 How you getting on with it then? Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 27, 2011 Author Share Posted March 27, 2011 Ha! Not ecstatic at the mo! Started a new thread here: http://forums.lr4x4.com/index.php?showtopic=66709&pid=573838&st=0entry573838 Quote Link to comment Share on other sites More sharing options...
Chris Sargent Posted March 28, 2011 Share Posted March 28, 2011 That doesn't sound too bad.... as you've said, it's a bit disappointing when you've just bought the car but you're bound to find a few things wrong with it over time after you've bought it.... and as the others have said, most things can be fixed and aren't critical to the running of the car. You should've seen what was wrong with mine when I bought it... http://forum.landrovernet.com/showthread.php/208284-Buying-a-LHD-Conversion-Freelander-Beware-and-some-advice. I'm pretty mechanically minded and I missed a few things on this one - but then, it's stuff you wouldn't spot on a test drive unless you started tearing out carpets and dashboards!!! Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 28, 2011 Author Share Posted March 28, 2011 Wow - that kind of puts it in context a little for me! Glad your problems are sorted out now though. I think with me its a dissapointment and that feeling that something else lurks beneath these problems (i guess thats a risk you take with any secondhand car though). (Plus - i am naturally a worrier and i worry if i have nothing to worry about!!! ) I traded in an old, yet pristine and very well running BMW for this, so it kinda feels like a step back in a way - we wanted another LR, as my girlfriend wasnt keen on the size of the 110 or the BMW and we wanted a slightly newer car than the BM too. Like i said in the other thread, the trader has said he will sort it, so i cant ask for much more, so will take it back this week and hopefully get these issues resolved. Then i can worry about the VCU etc..........! I might take your tack though from the other thread and replace it anyway for peace of mind once the warranty has run out on it. Quote Link to comment Share on other sites More sharing options...
Chris Sargent Posted March 28, 2011 Share Posted March 28, 2011 Mine is my girlfriends car and she bought it to replace a BMW Z3 - definitely feels like a step back for her! Still, whilst I've been working on hers in the garage, she's been driving around in my M3 with the roof down!<br> Quote Link to comment Share on other sites More sharing options...
