LR4x4 - The Land Rover Forum: K&N filter bore damage - LR4x4 - The Land Rover Forum
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
K&N filter bore damage pictures of my engine
#1 User is offline   JimAttrill
  • So important that they banned 50 000 IP addresses to shut me up
  • PipPipPip
  • Group: Moderators
  • Location:S 26°01.3' E027°58.5 1373m Johannesburg, South Africa
Posted 01 September 2007 - 07:00 PM
Posted Image
This was after 80 000 kms of a K&N which was regularly cleaned and reoiled using their kit.
1996 Defender 300Tdi 110 csw
#2 User is offline   white90
  • Treasurer
  • PipPipPipPip
  • View gallery
  • Group: Admin
Posted 03 September 2007 - 08:10 AM
moved here so more people can see/comment
Tony
Keep this forum independent click HERE.
#3 User is online   FridgeFreezer
  • Ferpect
  • PipPipPipPip
  • Group: Settled In
Posted 03 September 2007 - 08:12 AM
Blimey, the other four have worn completely away! :blink:
#4 User is offline   dollythelw
  • Волшебник
  • PipPipPip
  • Group: Settled In
  • Location:Hampshire/Slovakia/Hungary depends on the season :-)
Posted 03 September 2007 - 08:30 AM
excuse the heathen with his petrol powered shopping trolley :lol:
Jim does that wear extend around the whole circumference of the bore or just either side? hard to tell from the pics :unsure:
The House of Flying Spanners
"I wasnt born with enough middle fingers"
New project in build... its scary.
Blag-a-licious
#5 User is offline   BigSi110
  • Mmmmm - smelly Land Rovers !
  • PipPipPip
  • View gallery
  • Group: Settled In
Posted 03 September 2007 - 11:42 AM
Under what conditions was that engine running?
A man ain't truly been insulted until he stands butt naked in front of a woman and she didn't even notice.
Or care.
#6 User is offline   D9OSV
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 03 September 2007 - 12:01 PM
We see this kind of damage a lot on:
A/ Overland vehicles fitted with K&N or similair filters
B/ With tight fisted farmers that blow out there filters not replace them
C/ when people fit turbo diesel air filters to tdi's (Air filter is much shorter)
Makes you want to cry :(
Jim :)
The twinmotors are here............
www.Gigglepin4x4.net
The 8274 innovation company
#7 User is online   Aragorn
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 03 September 2007 - 12:02 PM
to be honest, badly filtered air would likely show in the valves and cylinder head more than the bores simply because its softer material, the piston crowns would also be pitted, from what i can see you have bore wear which looks to me to be caused by piston slap or hard use from cold (ie concentrated wear patches at either side of the top of the bore opposite the axis of the gudgeon pin)
I'm not advocating K&N filters BTW, i personally dont rate them much. Just dont think that wear solely indicates the filter was at fault
#8 User is online   Turbocharger
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 03 September 2007 - 12:28 PM
Jim, have you got any larger or close-up photos of the damage?
Regards
John
John Bickerton
www.teamnutter.co.uk
Home is where the heart is where the DVLA think you live
#9 User is offline   streaky
  • Old Hand
  • PipPipPip
  • Group: Settled In
Posted 03 September 2007 - 12:45 PM
It's the most common fault with free flowing air filters.........performance at a cost!
I can't understand why everyone wants to fit those things to engines. For racers...OK, you'd expect some attrician on a unit that has a limited life expectancy...but for everyday use or 'outback' work it's best leave the standard filters in or go for some type of pre-filter if possible.
My workshop in Dubai sends their performance engines back to JE on a regular basis..... the comments from JE are the same every time.... "you wouldn't believe the ammount of silt we found inside that engine!".
It will be interesting to see the condition of other components/shells etc as you get deeper into the block.
S.
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
