P38 - ABS, Hand Brake, TC light come on when i press the brake pedal
  • Please log in to reply
11 replies to this topic
#1 zim
zim
    Caring Forum Counsellor
  • Supporters
  • 1,967 posts
Posted 05 December 2009 - 07:01 PM
Hi,
So what's wrong with my p38 ?
When i press my brake pedal the traction control, handbrake and abs light come on for about a second then go out.
From searching google i've found :
On the P38 pressing your brake pedal suddenly,will activate your ABS,TC and handbrake lights.When you release the pedal the lights goes off.This is not a fault,as no faultcodes get stored,but a way to tell you the pressure in the accumulator is getting low.Its that round black unit on top of your ABS pump with the yellow warning sticker on it.This is a service replacement part from Land Rover.
I've got new fluid and brake pads.
Is this the case, or are there other possibilities ?
Thanks
Gordon
#2 elbekko
elbekko
    Captain Slow
  • Settled In
  • PipPipPip
  • 2,457 posts
Posted 05 December 2009 - 09:06 PM
Sounds like an electrical problem. Check your battery and alternator, I'd say.
Range Rover Classic '95 Softdash 300TDi
Range Rover P38a '99 4.6 HSE
#3 vougese39
vougese39
    Old Hand
  • Settled In
  • PipPipPip
  • 309 posts
Posted 07 December 2009 - 04:39 PM
when you bleed the brakes did the fluid get too low? as you could also have drawn air into the booster unit
ARMSON AE! FULL SERVICING,DIAGNOSTICS,V8 SPECIALIST, EMAIL armsonae@yahoo.co.uk http://armsonae.webs.com/
http://rocketsledtuning.webs.com/
#4 zim
zim
  • Supporters
  • 1,967 posts
Posted 07 December 2009 - 05:11 PM
there is no air in the system i dont think. it was doing it before i changed brake lines.
G
#5 David Sparkes
David Sparkes
    Old Hand
  • Settled In
  • PipPipPip
  • 1,851 posts
Posted 07 December 2009 - 07:08 PM
Why haven't you accepted the response you found originally via Google, that the accumulator needs changing?
#6 SteveG
SteveG
    Old Hand
  • Supporters
  • 2,880 posts
Posted 08 December 2009 - 09:44 AM
Just to hijack this thread - it is related ;)
How do you change the accumulator? I've already acquired a new one and O ring and I have read the procedure from the workshop manual, but want to know how you physically fit it.
It looks to be sealed (seems sensible given it's pressure ;)) but there doesn't seem to be any thread etc.
The reason I ask is that I've heard that if you swiftly change it out you don't have to bleed the system.
Thanks
Steve
#7 zim
zim
  • Supporters
  • 1,967 posts
Posted 08 December 2009 - 11:10 AM
if it's that which is at fault, then i'll be happy as it looks like an easy job to swap. but there were other answers i found on google including - change abs pump, change abs sensors, ecu fault etc. but the accumulator seemed to come up a couple times. also, when looking on google, i'm relying on people posting who i don't 'know' as such. i may not know many people on this site personally, but over the last couple years from the amount of time spent reading i can sort of tell who is knowledgable and who is just a 'keyboard' mechanic.
i hope this makes sense ?
steveg - there is an excellant review on rangerovers.net for changing it : http://www.rangerove...ccumulator.html
The above site proves my point about who you can trust, the amount of information on there is phenominal and goes into great detail, so in my mind, i don't mind trusting them about things...But there is no mention of my lights popping up :(
Regards
Gordon
#8 David Sparkes
David Sparkes
    Old Hand
  • Settled In
  • PipPipPip
  • 1,851 posts
I've never done the job, but isn't it simply a threaded fitting? So a small chain or strap wrench around the accumulator body should give you enough leverage to unscrew it.
Anything that stands over a thousand psi (80 bar) will stand the stress of a chain wrench.
Re RangeRovers.net, mention of things like lights flashing on are probably more common in Forum postings than in the main site.
When I read your fault description I didn't immediately think 'accumulator', but when that was offered as a solution it rang bells with me, so I'd be happy to accept that if it was my car playing up.
HTH
#9 zim
zim
  • Supporters
  • 1,967 posts
Posted 08 December 2009 - 11:33 AM
Thank you :)
#10 zim
zim
  • Supporters
  • 1,967 posts
Posted 08 December 2009 - 11:57 AM
HTH
i've never used that forum. that is full of info as well :) done some reading, and i'll be ordering an accumulator now :)
G
#11 j55ptk
j55ptk
    Newbie
  • New Faces
  • Pip
  • 5 posts
Posted 16 December 2009 - 06:56 AM
Hello, I've just bought a 1999 4.6 Hse with an identical problem, amongst others. Please let me know if the accumulator fixes it, Tim.
#12 zim
zim
  • Supporters
  • 1,967 posts
Posted 24 February 2010 - 11:13 AM
changing the accumulator fixed it :)
(belated reply)
