300 tdi excessive black smoke
  • Please log in to reply
5 replies to this topic
#1 gilloverland
gilloverland
    Member
  • Settled In
  • PipPip
  • 90 posts
Posted 03 July 2010 - 10:32 AM
Hi,
My 300TDI 110 now has around 215000 miles on it and I've noticed that when pulling away from a stand or powering up hills it makes quite a bit of balck smoke. Does anyone have any ideas on the quickist / cheapest way to cure this? I was thinking about starting replacing the injectors, AFAIK they are the origionals. Will the fuel pump have worn and be contributing to this or have I missed something?
There is absolutly no blue smoke its just thick black and gets worse if I push the peddle harder.
The vehicle is serviced religiously every 5500 miles so its not filters and has been smoking for a while now.
#2 tweetyduck
tweetyduck
    Overland Panic !!!!!
  • Supporters
  • 1,256 posts
Posted 03 July 2010 - 11:40 PM
from something i asked earlier thats overfuelling but i'm not an expert. Try turning the fuel down a bit. As I understand it it prety simple to do. I was shown what to do but not whats its called to explain this to you. If this is unclear (which it certainly is :P ) i'll post in more detail tomorrow.
I'm not sure why overfuelling would start without changing something so something must have worn.
M reg 1994 110 300Tdi CSW (MA9xxxxx)
Africa done....now in South America....
www.overlandbirds.com
#3 dailysleaze
dailysleaze
    Member
  • Settled In
  • PipPip
  • 180 posts
Posted 04 July 2010 - 11:58 AM
Black smoke means the fuel isn't burnt efficiently. Either too much fuel going in as above, or not enough air. Gunked up intercooler, hose split/collapse, dirty air filter or something else obstructing air flow?
#4 cackshifter
cackshifter
    Old Hand
  • Long Term Supporters
  • 827 posts
Posted 04 July 2010 - 05:53 PM
The above plus, if you have an EGR valve, I'd guess the manifold & head was coked up inside, or injectors might well be past best before at that mileage
#5 nicks90
nicks90
    Old Hand
  • Settled In
  • PipPipPip
  • 1,451 posts
Posted 06 July 2010 - 11:00 AM
read somehwere that the injectors should be recon/rejetted every 70k miles, so it could be the spray pattern is poor and its not burning all the fuel - hence the black smoke.
at that sort of mileage it wouldnt hurt to whip them out and get them done and if it doesnt cure the problem, at least you have done some good maintanence.
WWW.YORKSHIREOFFROADCLUB.NET
Familly friendly 4x4 club. Monthly RTVs, nav scatter, clubman challenges and pub meets.
#6 Aragorn
Aragorn
    Old Hand
  • Settled In
  • PipPipPip
  • 2,556 posts
Posted 06 July 2010 - 01:29 PM
Might be worth checking the turbo boost pressure?
If the turbo is worn or damaged it may not be flowing the correct amount of air, and as a result you get black smoke.
You should have more or less 1 bar of boost not long after 1900rpm, and it should hold there.
