Dave 63 Posted February 21, 2014 Share Posted February 21, 2014 Gents, just received black wing chequer plates minus Ariel hole in o/s one. Best way to fix them rivets/ counter sunk bolts, and do you think it's worth drilling the plate for the Ariel, relocate the Ariel on the roof? New to Landy scene, any ideas please Cheers Quote Link to comment Share on other sites More sharing options...
PaddyMac Posted February 21, 2014 Share Posted February 21, 2014 Hi Dave, This topic was covered on here before, so in case you want additional info check http://forums.lr4x4.com/index.php?showtopic=29847 I used alloy rivets with a bead of silicone sealant inside the edge of the chequer plate, but I have to admit I think countersunk screws do look a lot better.... Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 23, 2014 Share Posted February 23, 2014 Countersunk bolts look better, but they will be steel and will result in corrosion of the plate and the body panel underneath it. Aluminium alloy rivets will avoid this. It also avoids the possibility of someone undoing the bolts to steal the plates (assuming they had been used in conjunction with rivnuts, which would be the neat and easy method for bolts). Quote Link to comment Share on other sites More sharing options...
Dave 63 Posted February 24, 2014 Author Share Posted February 24, 2014 Thanks for the advice lads Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 24, 2014 Share Posted February 24, 2014 I used countersunk rivets. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 24, 2014 Share Posted February 24, 2014 I HAVE to be different. I countersink the holes. Then use button head screws... I did say I was different. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 24, 2014 Share Posted February 24, 2014 Countersink and then use button head screws?! I assume you mean countersunk screws? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 24, 2014 Share Posted February 24, 2014 Countersink and then use button head screws?! I assume you mean countersunk screws? NO BUTTON head screws I let the heads into the countersink Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 25, 2014 Share Posted February 25, 2014 What gain do you get from the countersinking then mike? The profile of the countersink and the buttonhead have nothing in common! Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 25, 2014 Share Posted February 25, 2014 AH !! Yes you do. The button head screws go inside the bars of the checker plate, If I had a means of just taking the "bars" off the checker plate I would do that instead.. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 25, 2014 Share Posted February 25, 2014 Ahh I see. A counterbore bit is what you need Just a random size one. http://uk.rs-online.com/web/p/product/5089250/?grossPrice=Y&cm_mmc=UK%7CShopping-_-Google+PLA-_-EXACT%7CCounterbores-_-5089250&kpid=&istCompanyId=f7e7b05b-2daf-4c0e-8825-3633baf8113b&istItemId=xwiprwqmp&istBid=tzit&gclid=COjNvryW57wCFYUIwwod0lQA2Q A cheaper one would be fine in ally. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 25, 2014 Share Posted February 25, 2014 Yes something like that would be fine. Quote Link to comment Share on other sites More sharing options...
