muss12 Posted August 18, 2014 Share Posted August 18, 2014 Trying to sort the nightmare of wiring that the person before put in, just stuck with the USB socket, I've got a raptor dash and got the cig socket and want the USB socket in as well, but wondered does it have to be wired into the ignition feed as well? Quote Link to comment Share on other sites More sharing options...
qwakers Posted August 18, 2014 Share Posted August 18, 2014 depends? do you want it permanent live or only on when the ignition is? Quote Link to comment Share on other sites More sharing options...
muss12 Posted August 18, 2014 Author Share Posted August 18, 2014 Answering my own question now aren't I, ignition feed would be best, but can I run straight off the battery with a inline fuse? Quote Link to comment Share on other sites More sharing options...
qwakers Posted August 18, 2014 Share Posted August 18, 2014 yup. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 18, 2014 Share Posted August 18, 2014 What USB connector are you using? I want one that will charge the ipad on the go, but they all seem to be £25 plus. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 18, 2014 Share Posted August 18, 2014 If you run a USB connector off of a permanent live I'd be tempted to see how much power it consumes when idle. Quote Link to comment Share on other sites More sharing options...
muss12 Posted August 18, 2014 Author Share Posted August 18, 2014 It's a mud uk one red78, I don't think my battery would last long with a permanent live Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 18, 2014 Share Posted August 18, 2014 If you run a USB connector off of a permanent live I'd be tempted to see how much power it consumes when idle. Shows my ignorance - I didn't even realise their would be one.... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 18, 2014 Share Posted August 18, 2014 There are a number of ways to drop the voltage from 12v to 5v, some are more effecient than others, some create more electrical noise than others. They will all have some amount of current drain even without anything connected to the output, although if they are properly designed it should be tiny (note, not everything is properly designed ). Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 18, 2014 Share Posted August 18, 2014 It suggests 15mA I think? http://www.bluesea.com/products/1016/Dual_USB_Charger_Socket/featured Those are the ones Mud UK sell. I always thought that figure needed a time factor to it as well like 15mAH? Quote Link to comment Share on other sites More sharing options...
qwakers Posted August 18, 2014 Share Posted August 18, 2014 if it draws 15ma then youve got a couple of months before it even begins to flatten the battery. 1 Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 18, 2014 Share Posted August 18, 2014 It suggests 15mA I think? http://www.bluesea.com/products/1016/Dual_USB_Charger_Socket/featured Those are the ones Mud UK sell. I always thought that figure needed a time factor to it as well like 15mAH? If it draws 15mA then in one hour it will draw 15mAH So if you have an 80AH battery you are good for over 5000 hours as qwakers says Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 19, 2014 Share Posted August 19, 2014 Thanks both - that's the one o have fitted too Quote Link to comment Share on other sites More sharing options...
muss12 Posted August 19, 2014 Author Share Posted August 19, 2014 Thanks for the help gentlemen Quote Link to comment Share on other sites More sharing options...
muddy Posted August 20, 2014 Share Posted August 20, 2014 I have wired my cb, usb and fag lighter s into ign live but then put a diode in and a perm li e switch so I can charge stuff and talk on the cb without the keys being left in. Will. 1 Quote Link to comment Share on other sites More sharing options...
muss12 Posted August 20, 2014 Author Share Posted August 20, 2014 Quick one, did you put in a reducer 12v to 5v? Just been too maplins and he told me a 1a reducer isn't enough to charge my phone or sat nav If so what one did you use Quote Link to comment Share on other sites More sharing options...
