speedometer problems . help
need some advice. defender 90. 300 tdi auto
i have recently got a 300 tdi ,autobox and transferbox from a discovery.
the transfer box has a speedsensor fitted , instead of a speedo drive to run cable.
what parts will i require so i can use my 90 speedo cable .
the parts place at local 4x4 place isnt being very helpful.
thanks in advanced
I agree with everyone, I have a Range Rover classic with speed sensor speedo, which has never worked, I changed the sensor which is just a box that a short speedo cable goes into. The gearbox end is just the same as the good old speedo cables. My speedo still does'nt work, an ECU problem I think.
