miketomcat Posted March 2, 2015 Share Posted March 2, 2015 Could one of you kind fellows take a measurement from the centre of the rear wheel to the face of the cross member. I'm trying to work out what exhaust might be close to fitting the ibex currently I'm thinking td5 110 rear, chopped td5 130 mid and disco 200tdi front. Thanks mike Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 2, 2015 Share Posted March 2, 2015 I made a 300 tdi disco one fit mine. 10 inches of straight fitted to the centre section and a few bits cut and shut behind the axle to shorten it up a bit. V Straightforward. I did have a Janspeed Stainless system there though so it kind of forced my hand a bit. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted March 2, 2015 Share Posted March 2, 2015 I've got a rear section in the shed at home which I mistakingly bought - I think it might be either a 200Tdi or 2.5NA rear section for a 110 rather than the 300Tdi which I needed. It had the wrong mating flange for mine. Since I'm never going to use it then if you can put it to use then by all means have it. Perhaps a small donation to the forum? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 2, 2015 Author Share Posted March 2, 2015 I've got a stainless disco rear but it was to far off to make it worth cutting. I reckon the td5 110 will be pretty close hence wanting the measurement. Ed I may be interested but I have to have a rolled tail pipe for the iva and I was aiming at rear exit but I'll do a bit of research and get back to you. Mike Quote Link to comment Share on other sites More sharing options...
stuck Posted March 2, 2015 Share Posted March 2, 2015 If no one has posted the dimension I'll measure my 110 when I get home. Do you want the measurement to the inside edge of the cross member? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 2, 2015 Author Share Posted March 2, 2015 The rear most face (ie rear of body) of the cross member to wheel centre would be great it's so I can work out if my rear overhang is similar or not thanks. Mike Quote Link to comment Share on other sites More sharing options...
AMB Posted March 2, 2015 Share Posted March 2, 2015 '98 300Tdi, 110 CSW. From position directly above centre of rear wheel to the rear face of the cross member just measured at 92cm. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 2, 2015 Author Share Posted March 2, 2015 Purfect many thanks. Mike Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 2, 2015 Share Posted March 2, 2015 If you need to have a rolled tailpipe landrover do a rolled end section that knocks on over the standard 300tdi 110 tailpipe if that is any help, part number NTC2022 Quote Link to comment Share on other sites More sharing options...
