Maverik Posted May 8, 2013 Share Posted May 8, 2013 Hi folks, Digging around the Camel 110, i've found what I think is a LR fit split charge system... Can anyone help me cofirm as to whether or not it is a split charge system... I'll post up some pictures later. Cheers Mav Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2013 Share Posted May 8, 2013 Factory fit split charge unit lives in the engine bay driver side right corner outboard of the brake servo. parts shown in http://lrcat.com/#31/4/52837 looks like this Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 8, 2013 Author Share Posted May 8, 2013 Thanks Ralph, was this the only system LR installed? - I've got 2 relays hidden behind the birds nest of wires where the engine loom/rear loom connectors join up the inboard side of the steering column... any clues as to what they're for? H Reg 1991 Genuine 200tdi... Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2013 Share Posted May 8, 2013 AFAIK the only other split charge for 90/110/Defender was this one http://lrcat.com/#31/4/52836 the unit looks like a ign coil. I believe it wasn't fitted to tdi vehicles. one of those relays should be the glowpkug timer, don't know about the 2nd relay, what colour wires go to it ? might give a clue, can you put a photo up too. Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 8, 2013 Share Posted May 8, 2013 When I worked in Prototype Development at LR the common split charge system fitted to press vehicles and the like used a Voltage Sensitive Relay (yellow in colour, three pin, with lr part no) as found in heated rear window circuit on defender, and a suitably rated relay/solenoid/contactor to handle the alternator output You may have something similar fitted Quote Link to comment Share on other sites More sharing options...
western Posted May 8, 2013 Share Posted May 8, 2013 VSS is usually behind the dash in right corner behind the 3 rocker switches between drivers door & steering column, sits next to the rear screen heater relay [if fitted] Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 10, 2013 Author Share Posted May 10, 2013 Here are the relays I'm talking about... I'm going to take the dash apart this evening as have some other wireing issue i need to check out, I'll take some pictures of behind the dash see what that reveals... Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 they might be for the extra lights or winch controls, don't look anything like my split charge relay, Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 10, 2013 Author Share Posted May 10, 2013 They're not on my critical to do list but its got me interested so I'll do some have a further dig around see if I can find out more. Thanks for your feedback Ralph. Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 Camel Trophy club http://www.cameltrophy.co.uk/ might be able to advise what those are for. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 10, 2013 Author Share Posted May 10, 2013 Yeah I'm a member of CTOC, I actually thought this a LR accesory so decided to post up my query here. Quote Link to comment Share on other sites More sharing options...
western Posted May 10, 2013 Share Posted May 10, 2013 just a thought does the 110 have twin fuel tanks & a rocker switch on bottom of instrument pack to switch between tanks, looking at the parts book, there is a loom item 1 for twin fuel tanks, on page 696 http://www.retroanaconda.com/landrover/parts_books/110/8_body_electrics_p667-740.pdf but I'm not sure if the 3 relay blocks fit on dash side of bulkhead or where your relays are, it's not a very accurate diagram. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 12, 2013 Author Share Posted May 12, 2013 Hi Ralph, good thought, I was thinking that too, she does have twin tanks, but its the mechanical army type switch over system, with 2 valves and a few linkages operated from the front of the seat box... I went digging around behind the dash today and found a fair few bits I wasn't familier with it being a 1991 it was the newer wireing set-up... Here's a few bits... Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2013 Share Posted May 12, 2013 the white plug is for the dim dip voltage transformer unit this one. the black rubber plug might be the connection from dash to engine loom for petrol engined vehicles. can't quite make out the wire colours on the centre photo, can you list them & we should be able to find them in the wiring diagrams Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 13, 2013 Author Share Posted May 13, 2013 Any idea's on the yellow/brown coloured relay holder? presently got no relay in it and maybe got some kind of wire stuck in it as a bipass... couldn;t quite see it properly... Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2013 Share Posted May 13, 2013 never seen a relay holder that colour before, only black ones, how many wires & what colours are they ? Quote Link to comment Share on other sites More sharing options...
Kierran.M.110 Posted May 13, 2013 Share Posted May 13, 2013 western and maverik i would love to know what the yellow connector is because im sure there is one bolted on the bulkhead of mine Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2013 Share Posted May 13, 2013 unfortunately the wiring diagrams don't detail relay holder colours, would be good if the did. Quote Link to comment Share on other sites More sharing options...
alfaman Posted September 23, 2013 Share Posted September 23, 2013 western and maverik i would love to know what the yellow connector is because im sure there is one bolted on the bulkhead of mine The yellow connector is for the Voltage Sensitive Switch. I have one of those on my dash with a Yellow relay in it. It should have 3 wires connected to it, Black, Brown and a Black/Slate. Hope this helps. Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2013 Share Posted September 23, 2013 I'll have a look at my old dash area loom when in from work tomorrow , my currently fitted loom is an autosparks loom & the VSS socket is black. Quote Link to comment Share on other sites More sharing options...
