Quagmire Posted July 24, 2014 Share Posted July 24, 2014 Chaps, What are the connectors used on the tps and the idle air stepper on a 4.6 Plenum? See below. I think the TPS is the same as injectors but 3-way (junior timer?) but have no idea on the idle valve. Any pointers greatly appreciated. Cheers! Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted July 24, 2014 Share Posted July 24, 2014 Nigel does the connectors for tps but not sure about idle valve Quote Link to comment Share on other sites More sharing options...
MECCANO Posted July 24, 2014 Share Posted July 24, 2014 Same as what i have on the t16, available from polevolt http://www.polevolt.co.uk/acatalog/info_20900_3.html Got loads of second hand ones on various looms if you need a pig tail. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted July 24, 2014 Author Share Posted July 24, 2014 Thanks, that's what I thought it was - just need to figure out the air valve now. *edit - might it be one of these? http://www.polevolt.co.uk/acatalog/info_SC4_66KIT.html Quote Link to comment Share on other sites More sharing options...
Cheesy Posted July 24, 2014 Share Posted July 24, 2014 You just need to make sure if the connector (for tps) has the two posts that stick up to hold the spring clip that the are on the side with two location blocks other wise it will not fit... dont ask me how I know that. edit, the one in the link above is the correct way, not all of them are Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 25, 2014 Share Posted July 25, 2014 Does this help? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted August 14, 2014 Share Posted August 14, 2014 The Idle Air Stepper Motor connector is a 4-way female Delphi sealed MetriPack 150.2 'pull-to-seat' device connector. It can be bought from Simtek - http://www.simtekuk.co.uk/product.php/4_way_delphi_pull-to-seat_sensor_connector/?k=:::2644147 It's also used on Ducati motorcycles - http://www.ebay.co.uk/itm/301134899449 The TPS connector, as everyone has already said, is a 3-way female JPT connector. . Quote Link to comment Share on other sites More sharing options...
