landy V8 Posted January 25, 2011 Share Posted January 25, 2011 greetings instead of changing the whole axle is there a way of converting it from drum to discs using parts alone. it's just a thought,as getting hold of a salibury disc axle is a bit on the pricey side. unless someone has got they want to get rid of on the cheapish. thanks Ralph Quote Link to comment Share on other sites More sharing options...
TD Man Posted January 26, 2011 Share Posted January 26, 2011 greetings instead of changing the whole axle is there a way of converting it from drum to discs using parts alone. it's just a thought,as getting hold of a salibury disc axle is a bit on the pricey side. unless someone has got they want to get rid of on the cheapish. thanks Ralph I think there was a kit or mod using RRC rear discs and backing plates but I'm not sure what exactly was used Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 26, 2011 Share Posted January 26, 2011 Zues engineering do a conversion, comes in at about £500 last time I spoke to them. My link Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 26, 2011 Share Posted January 26, 2011 This has been covered recently, and in detail, I suggest a search Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 26, 2011 Share Posted January 26, 2011 Two ways of doing it: Using the proper 300Tdi stub axles and hubs, with 110 rear calipers and discs. Using early 90/110 front hubs with the existing stubs axles, with 110 rear calipers and discs. This guide shows the latter: http://forums.lr4x4.com/index.php?showtopic=11685 Mine is the former, which negates the need for the spacer, as it's integral to the later stub axles. Quote Link to comment Share on other sites More sharing options...
wack61 Posted January 26, 2011 Share Posted January 26, 2011 My 110 had a disc braked salisbury with a goosed diff , I bought a good salisbury with drums and the mechanic I use changed the drums for discs , total cost including the swap over removing the old axle and refitting the new one inc new oil was £240 + £100 for the secondhand axle so job done £340 Quote Link to comment Share on other sites More sharing options...
