TD5 fuel pump electric plug?
dantastic
Full info courtesy of PaulMC in this post...not quite as easy as it would appear. Easiest solution is probably a TD5 disco scrapper...
Matt
Further to my post in that thread, here are the BMW part numbers for the 4-way connector, terminals and wire seals -
BMW connectors
The 4-way connector housings are available from BMW dealers as –
4-way male housing – 61 13 8 367 075 (superceding – 61 13 8 367 071)
4-way female housing – 61 13 8 367 076 (superceding – 61 13 8 367 072)
I can only find part numbers for unsealed terminals, the sealed ones only seem to be available pre-crimped to short ‘repair cables’, and then, only for up to 2.5mm2 cable.
There is a 2.5 - 4.0mm2 female terminal listed, but no male terminal, that I could see –
Female terminal, sealed, 2.5 - 4.0mm2 – 61 13 8 352 926
Wire seal for above – 61 13 8 352 924
The BMW part numbers for the unsealed male and female terminals to suit 1.0 – 2.5mm2 cable and 2.5 – 4.0mm2 cable, are –
Male terminal, unsealed, 1.0 – 2.5mm2 – 61 13 1 376 193
Male terminal, unsealed, 2.5 – 4.0mm2 – 61 13 1 376 195
Female terminal, unsealed, 1.0 – 2.5mm2 – 61 13 1 376 204
Female terminal, unsealed, 2.5 – 4.0mm2 – 61 13 1 376 206
To connect to the TD5 in-tank pump/sender, you need a female connector housing and female terminals.
