@@@ Posted January 8, 2017 Share Posted January 8, 2017 Hi In the process of adding heated mirrors to my td5. I decided as I wasn't going to install a heated front screen and the switch would fit in the standard dash I'd use the switch for a heated front screen (YUG000460LNF) to turn the heated mirrors on and off. unfortunately it seems the switch will only power the mirrors when held in. looking at the wiring for a heated front screen it appears the switch gives a pulse to a timer relay which then energises the relay to power the screen. Which I think leaves 3 options 1. Add a timer relay and wire it up per the standard front screen wiring 2. replace the standard relay with a latching/impulse relay 3. get a new switch body and connector from a latching type switch and swap the fascias Any thoughts on those options, whether they will/won't work an better options? Thanks in advance Mark Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted January 8, 2017 Share Posted January 8, 2017 There are loads of threads about retrofitting and wiring the heated front screen, most retrofits use the timer relay bought from VWP and carry out the internal switch mod to allow the aftermarket timer relay to work. You're doing most of the donkey work with the wiring to fit the heated mirrors Personally I'd fit the timer relay as it means should you go down the HFS route (maybe upgrade if the screen gets damaged) then the fiddly part is done. Quote Link to comment Share on other sites More sharing options...
western Posted January 8, 2017 Share Posted January 8, 2017 No 3 would work, just use the switch body for extra front fog or driving lights. see item 1 YUG000540LNF click + to read the part number in http://www.albrit.de/UNI.cfm?PAGE=763860&SPRACHE=EN it's a latch on switch, push on & push off, not spring loaded. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 8, 2017 Share Posted January 8, 2017 But those are £60 each Ralph ! Mo Quote Link to comment Share on other sites More sharing options...
western Posted January 8, 2017 Share Posted January 8, 2017 might be the only way to get a matching switch, or from a breaker, ebay has some but in region of 60 quid pluspostage. Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted January 8, 2017 Share Posted January 8, 2017 (edited) You can swap the fronts on those type of switches so could get a cheaper on/off switch, one for a puma heated seat would do and is considerably cheaper. The switches in the dash on a disco 2 are the same as well so one of those could fit the bill. Edited January 8, 2017 by Mudmonkey Quote Link to comment Share on other sites More sharing options...
muddy Posted January 8, 2017 Share Posted January 8, 2017 Are the plugs different on the back of the switch ? Quote Link to comment Share on other sites More sharing options...
Mudmonkey Posted January 8, 2017 Share Posted January 8, 2017 14 minutes ago, muddy said: Are the plugs different on the back of the switch ? IIRC just the keyway is different which could soon be cut off or the proper connector is probably only a couple of quid. Quote Link to comment Share on other sites More sharing options...
@@@ Posted January 9, 2017 Author Share Posted January 9, 2017 Looks like I can get a puma heated seat switch with connector for £15 so that looks the cheapest/easiest route, thanks all 1 Quote Link to comment Share on other sites More sharing options...
