Steve Warman Posted February 12, 2017 Share Posted February 12, 2017 I have an infrequent problem with a fuse that blows that leaves the engine effectively dead. I've had the disco 1, 300tdi auto, for around 4 years and not had any issues. The first time it happened it took some searching to find out what may be involved but that was after a lift home on the back of a flatbed. The second time was today and easily remedied for now. The symptoms of the issue once the fuse has blown is that the starter turns over but the engine doesn't kick in and the glow plug light doesn't come on when starting. Once the fuse is replaced we;re back to normal working order. In both occasions when this has occurred i have been accelerating up hill when all power is lost and the fuse has blown. Has anyone been in this situation before or would anyone know where to start looking to see what the underlying issue could be? Thanks Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 13, 2017 Share Posted February 13, 2017 Hi, what year is the vehicle and tell me exactly which fuse, F7(20A) engine bay or which one? Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 14, 2017 Author Share Posted February 14, 2017 It's a 1995 and the fuse is the 10a fuse 3 on the lower satellite section under the steering column. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 14, 2017 Share Posted February 14, 2017 Remove the glow plug timer unit and se if it blows then... if not the problem is on that path and we'll speak then Quote Link to comment Share on other sites More sharing options...
SPendrey Posted February 14, 2017 Share Posted February 14, 2017 Interested in your suggestion... why would the glow plug timer/relay be the cause if the failures occur while driving. Doesn't the timer only activate at startup? I suppose it isn't switching off then that could cause the fuse to blow? Quote Link to comment Share on other sites More sharing options...
teabag Posted February 14, 2017 Share Posted February 14, 2017 Fuse 3 looks after the supply to: fuel cut shut-off solenoid, EGR control solenoid, EGR valve control module and the glow plug timer relay. So not that bad with the EGR being the primary suspect. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 14, 2017 Share Posted February 14, 2017 (edited) 1 hour ago, SPendrey said: why would the glow plug timer/relay be the cause if the failures occur while driving. Cos you didnt say in the first post that it occurs while driving .... though it's possible to be an intermittent short within it ... 1 hour ago, teabag said: Fuse 3 looks after the supply to: fuel cut shut-off solenoid, EGR control solenoid, EGR valve control module and the glow plug timer relay. So not that bad with the EGR being the primary suspect. On non EDC modells, this one being an auto i presumed it's with EDC so F3 goes to glow plug timer and ECU cos the EGR is managed by the ECU on these Edited February 14, 2017 by sierrafery Quote Link to comment Share on other sites More sharing options...
teabag Posted February 14, 2017 Share Posted February 14, 2017 (edited) No EDC fitted to 1995MY tdi auto. EDC was introduced and fitted to 1996MY tdi auto model's onwards. So will only comment on vehicle with date as stated. Edited February 14, 2017 by teabag Quote Link to comment Share on other sites More sharing options...
teabag Posted February 14, 2017 Share Posted February 14, 2017 (edited) 3 minutes ago, teabag said: As stated EDC equipped vehicles it could be more involved now with the involvement of an ECU. Edited February 14, 2017 by teabag Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 14, 2017 Share Posted February 14, 2017 Might be some VIN related confusion cos the diagram is from '95 D1's electrical troubleshooting manual Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 14, 2017 Share Posted February 14, 2017 (edited) I made some research on this and as i said it might be a confusion cos according to Microcat the EDC ECU p/n ERR5985 [ 2500 cc - Diesel - TDi - EDC - Europe ] was valid to VIN ......MA163103 which means built in '95 so it depends on the VIN of the OP's vehicle ...anyway the problem is somewhere on that path from F3 as in the diagram Edited February 14, 2017 by sierrafery Quote Link to comment Share on other sites More sharing options...
teabag Posted February 15, 2017 Share Posted February 15, 2017 (edited) The 1996MY D1 was in the showrooms in June1995, hence the vehicle being built in 1995 the VIN is MA. Just to add as I was looking to purchase a disco back then, there was few other important changes made to the 1996MY, which continued through 1997 until changes were made again when the 1998MY D1 was introduced. Edited February 15, 2017 by teabag Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 15, 2017 Share Posted February 15, 2017 so can i spresume then that a '95 D1 is with EDC? Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 15, 2017 Author Share Posted February 15, 2017 I managed to have a look under the bonnet this morning to see if I could see anything amiss and noticed a wire that runs from the glow plug timer relay to another box near the battery. The wire was trapped under the battery and when i managed to get it out from underneath noticed that it had been squashed and worn through I've taped up, for the time being, any exposed sections Quote Link to comment Share on other sites More sharing options...
teabag Posted February 15, 2017 Share Posted February 15, 2017 48 minutes ago, sierrafery said: so can i spresume then that a '95 D1 is with EDC? Not the 1995MY but a1996MY built in 1995 then yes, as alway there's two model years per year. As an example when I purchased my D1 alongside it was the 1998MY D1 both he same price, but there was a deal to be done with the outgoing model, so for me, that was £5000 off, or to be exact a load of extras and two years free servicing. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 15, 2017 Share Posted February 15, 2017 14 minutes ago, Steve Warman said: I managed to have a look under the bonnet this morning to see if I could see anything amiss and noticed a wire that runs from the glow plug timer relay to another box near the battery. The wire was trapped under the battery and when i managed to get it out from underneath noticed that it had been squashed and worn through I've taped up, for the time being, any exposed sections And did this fix things? Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 15, 2017 Author Share Posted February 15, 2017 So far so good but it's intermittent enough to be annoying and blow again at any time Given that it looks to be part of the wiring in the diagram above I'll keep an eye on it and see Thanks for your help Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 15, 2017 Share Posted February 15, 2017 (edited) welcome, let's hope it's fixed, just to know in case it isnt fixed is your's with EDC or not? Edited February 15, 2017 by sierrafery Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted February 15, 2017 Author Share Posted February 15, 2017 I don't know, how do I tell? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted February 15, 2017 Share Posted February 15, 2017 If it has an engine ECU(like in the pic) or not behind the right kick pannel? Quote Link to comment Share on other sites More sharing options...
teabag Posted February 15, 2017 Share Posted February 15, 2017 Do you have the throttle cable if no you have EDC, no need to go under the dash removing the kick panel. Quote Link to comment Share on other sites More sharing options...
steve_a Posted February 17, 2017 Share Posted February 17, 2017 EDC still has throttle cable doesn't it. 99% sure mine did, as the cruise control would operate the vacuum and drag the pedal down and I'm sure I remember the cable being on the pump. Quote Link to comment Share on other sites More sharing options...
teabag Posted February 18, 2017 Share Posted February 18, 2017 (edited) With the EDC system there's no mechanical link (cable) between the accelerator pedal and the fuel injector pump, hence the term 'drive-by-wire'. Edited February 18, 2017 by teabag Quote Link to comment Share on other sites More sharing options...
