bushwhacker Posted April 3, 2017 Share Posted April 3, 2017 (edited) Don't laugh Will a series 2/3 roof, rear door and sides fit a 90. I really don't know. Edited April 3, 2017 by bushwhacker Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2017 Share Posted April 3, 2017 doors will fit if you use the correct lock striker on the door pillar, roof would but only with the matching series LR windscreen frame. a backward step as the 90 screen is much taller & gives a better road view forward. 1 Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted April 3, 2017 Author Share Posted April 3, 2017 Thank you. And very well explained. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 4, 2017 Share Posted April 4, 2017 (edited) Are you sure about the roof because I'm pretty sure the sides don't fit a 90. 110/109 I believe will. 88 sides fit a 110sw but 90 sides don't. Truck cab should fit but as western says with a series windscreen. Mike Edited April 4, 2017 by miketomcat 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 4, 2017 Share Posted April 4, 2017 don't know about the upper side panels, Yes the 88 side panels fit a 110 station wagon to convery to utility plain side spec. Quote Link to comment Share on other sites More sharing options...
neil110 Posted April 4, 2017 Share Posted April 4, 2017 The upper body sides are not a straight swap type fit. Series upper body sides are shorter than those of a 90. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 4, 2017 Share Posted April 4, 2017 Therefore the roof won't fit either. Mike 1 Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 4, 2017 Share Posted April 4, 2017 (edited) The 88" roof will not fit a 90 - sorry, we tried. The 88" side panels will not fit a 90 - sorry, we tried. The 88" side panels will fit a 110 SW - we tried. The 109" roof will fit a 110 if the Series windscreen is fitted - we had it like that some time ago.. The doors, as mentioned, are the same dimensions but will at times need other striker plates. Edited April 4, 2017 by Arjan 1 Quote Link to comment Share on other sites More sharing options...
