Cannon Posted June 10, 2017 Share Posted June 10, 2017 1980 classic Range rover (2 door ) is missing "SAL" ON the VIN PLATE AT radiator.,,,,,so number starts with *LH... all paperwork matches the plate. To carry out a history check on this R/R I had to include "SAL" to get report. also No number stamped on chassis??? Has any one noticed this previously on a classic range rover? Quote Link to comment Share on other sites More sharing options...
Davo Posted June 14, 2017 Share Posted June 14, 2017 So there's no number on the outside front of the RH chassis rail? It sounds very odd. What's the radiator plate look like? Can you post a photo? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 14, 2017 Share Posted June 14, 2017 Ex-mod/special vehicles? Quote Link to comment Share on other sites More sharing options...
Arjan Posted June 15, 2017 Share Posted June 15, 2017 Hmm.... Be careful - it should have a VIN no behind the RH front wheel in the chassis - often hard to see. Wirebrush is your friend. Please post a picture of the VIN Plate - very interesting to see that. Quote Link to comment Share on other sites More sharing options...
paintman Posted June 16, 2017 Share Posted June 16, 2017 (edited) Mine's a 1986 & the chassis number is stamped on the outside right front (UK driver's side) of the chassis between the front of the chassis spring mounting and the front suspension radius arm. Took a fair amount of wire brushing to see it! ETA. Just found this on another website: http://www.lrfaq.org/FAQ.3.Chassis_Numbers.html Range Rovers Stamped on the right hand side chassis member forward of the front spring mounting turret RANGE ROVER Classic with Vogue body (not sure about NAS County) has chassis number stamped in rear/passenger cross member (in front of rear wheel) Edited June 16, 2017 by paintman Quote Link to comment Share on other sites More sharing options...
