Removing 300Tdi, g'box and t'box together
Troll Hunter
I'm about to remove the engine and transmission, as a combined unit, from my 110 CSW and need some advice, please.  When it is out, are there any special considerations regarding setting it on a concrete floor?  Should it be supported in specific locations to avoid sump deflection/damage, for example?
Many thanks, in advance, for any advice.
Mike
Yes, I would try to avoid sitting the engine on it's sump. Maybe try and support it on each of it's engine mounts.
The gearbox and transfer box are all solid, but as the transfer box drops down diagonally, it may need chocking with wood as the whole unit (engine ans boxes) may topple over!
Steve
  • Like 1
I never put engine & gearbox straight onto concrete.
Get wooden block and some planks to level the thing out - and make sure it can fall over : they are very unstable..
