simonpelly Posted November 7, 2017 Share Posted November 7, 2017 Hi Folks, 1997 Defender 110 300Tdi - Installation of a rev counter into instrument dash. Essentially removing the clock and replacing with a rev counter - albeit likely to fit next to speed and shift over the fuel gauge. Thinking then of mounting a clock (rectangular old style) on the centre dash between rear wash wipe and cigarette lighter. However, have to put this project on ice for a little while. Before I forget though, would like to have some feedback on my thoughts on how to wire this all up. Thinking of a piggy back blade onto the ignition switch (inline fuse) and connecting/extending the existing C914 clock connector ouput. Trying to keep as simple as possible while keeping the wiring loom as per factory. Please see image attached. Thoughts? Many Thanks, Simon... Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted November 7, 2017 Share Posted November 7, 2017 Cigarette lighter will have illumination and earth wires so easy enough to tap into them, then a constant live feed up from the fuse box for the clock. Its not much of a run either way, longest will be the alternator signal wire. Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2017 Share Posted November 7, 2017 Found my notes from Aug 2000 when I fitted my rev counter. LR part AMR5724 0 to 5000rpm illumination to any existing gauge illumination wiring red/white trace] on rev counter terminal 2 to 'W' terminal on alternator terminal + [positive] to a ignition controlled feed [plain white wire] terminal - [negative] to a earh point set 3 sliders to 1 & 3 up & 2 down that should give a idle rev reading of 750 to 800rpm. this link might help Quote Link to comment Share on other sites More sharing options...
Cchase Posted November 7, 2017 Share Posted November 7, 2017 Be careful to keep the alternator signal wire away from the exhaust...don't ask. I quite like having a tach. I got a round clock and mounted it with an oil pressure gauge and the fuel gauge to the centre. On the binnacle I have a oil temp, coolant temp, tach, speedometer (from left to right) Good luck, C Quote Link to comment Share on other sites More sharing options...
simonpelly Posted November 7, 2017 Author Share Posted November 7, 2017 Hi Folks, Great responses. Much appreciated. I'll write up how it goes when job is done and post my notes. Looking forward to having a tachometer. Many Thanks, Simon.. Quote Link to comment Share on other sites More sharing options...
