Smego Posted March 12, 2018 Share Posted March 12, 2018 (edited) Assume this is likely to be a sticky relay? Having to sometimes stall it to cut the engine, seems to be when it it raining more? 1988 ex rd truck fitted with a defender 200tdi btw Edited March 12, 2018 by Smego Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 12, 2018 Share Posted March 12, 2018 There is no relay. Power is straight from the igniton switch to the fuel solenoid. Could be the ignition switch, could be the fuel solenoid, could be back feed from the alternator through the charge light (as that era did not have a diode). YOU need to troubleshoot. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 12, 2018 Share Posted March 12, 2018 Can be a sticky fuel stop solenoid or carp jammed in it stopping it closing. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted March 12, 2018 Share Posted March 12, 2018 as above - easiest way to see if it is a sticking fuel stop solenoid is to pull the cable off the top of the Solenoid when it is running on. If it stops immediately your problem is electrical (ignition switch or back feed from alternator) if it carries on then the fault lies with the stop solenoid itself. Worth taking out and cleaning first as Ross mentions there could be some carp in there Quote Link to comment Share on other sites More sharing options...
Smego Posted March 14, 2018 Author Share Posted March 14, 2018 Without patronising me, can anyone give me details of where to look for this fuel stop solenoid, is it something a diy not particularly mechanically minded person could do? I can do electrics so that bit isn't a worry. Ta. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 14, 2018 Share Posted March 14, 2018 A post from way back when with a pic: Quote Link to comment Share on other sites More sharing options...
Smego Posted March 14, 2018 Author Share Posted March 14, 2018 (edited) Thank you! Just what I needed, don't know why that didnt come up when I searched? Edited March 14, 2018 by Smego Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 14, 2018 Share Posted March 14, 2018 You ran out of google-fu Quote Link to comment Share on other sites More sharing options...
