ThreeSheds Posted March 14, 2018 Share Posted March 14, 2018 Hi... I have done a search - honest! but cant find threads on this anywhere... No doubt somebody will post links to several now Having various electronic packages under the front seats troubles me - especially with past knowledge of the efficacy of Disco door seals... Even a relatively gentle bit of wading could result in a flooded gearbox ecu, cd autochanger and amplifier. I don't actually want to remove any of these components, but was thinking that repositioning them a little more out of harm's way would be a good idea. So I am looking for suggestions, or links to a previous thread on this please. The main thing that is troubling me is where to put them, and will extending the wires require any special (shielded?) cables? Thanks Rog Quote Link to comment Share on other sites More sharing options...
elbekko Posted March 14, 2018 Share Posted March 14, 2018 If you feel like soldering a billion wires, it can be done. I doubt it'd require anything shielded. Maybe put them in a waterproof enclosure in the original location? But do make sure they can still cool properly. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 14, 2018 Share Posted March 14, 2018 Buy a big bag of glue-lined heat-shrink pre-cut sleeves and a load of assorted coloured wire, a soldering iron, and a lot of patience! Cut, strip, sleeve, solder, shrink one at a time... lather, rinse, repeat... make it as long as you like! Quote Link to comment Share on other sites More sharing options...
steve_a Posted March 15, 2018 Share Posted March 15, 2018 The autobox ecu can apparently reach fine without extension to sit vertically in the centre console. I keep meaning to do it, but we don't do a lot of wading so not been a big deal. This does, for a quick fix, get you probably 6" of extra depth, by that time the throttle pedal probably won't work anyway That would be the next one to move up - the defender guys have done this, but not sure I've heard about it on a disco Quote Link to comment Share on other sites More sharing options...
