Trixxeo Posted May 1, 2018 Share Posted May 1, 2018 I just received some new doors for my 90. The lift up handle but with a window winder type. Now I've fitted one door and it fits alright, however it's not perfect. The gap around the door is correct and it hangs straight. But the bottom left corner goes inwards past the body line, and the top right sits proud of the windscreen line. Would placing an additional spacer behind the top hind push the top in and the bottom out? I haven't got the bottom door seal fitted which may push the bottom out a little. But obviously won't account for the top. My other thinking was the door just needs twisting a little with some force on the top. Quote Link to comment Share on other sites More sharing options...
neil110 Posted May 2, 2018 Share Posted May 2, 2018 It is possible to adjust the fit of the door with plastic shims under the door hinges. These are the type for the earlier, smaller, hinges. Cannot find the No for the later hinges at the moment. https://www.brit-car.co.uk/search.php?query=mwc1898&xBrand=&part_type=&xSupplierID=&product-sort=&xPerPage=10 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 2, 2018 Share Posted May 2, 2018 On the Defender production line they have a couple of big burly chaps with rubber mallets to adjust them, I never knew you could bend a Defender door that far! Quote Link to comment Share on other sites More sharing options...
Trixxeo Posted May 2, 2018 Author Share Posted May 2, 2018 1 hour ago, neil110 said: It is possible to adjust the fit of the door with plastic shims under the door hinges. These are the type for the earlier, smaller, hinges. Cannot find the No for the later hinges at the moment. https://www.brit-car.co.uk/search.php?query=mwc1898&xBrand=&part_type=&xSupplierID=&product-sort=&xPerPage=10 I've got loads of the larger plastic ones that are rounded on the corners laying around. I'll see if one of those works. Just not sure if it will be enough to push the top in and the bottom out. Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted May 2, 2018 Share Posted May 2, 2018 Some forceful tweaking may be required, a few tugs at the door frame can provide enough "adjustment" to aid fitment. Don't get too carried away though! Quote Link to comment Share on other sites More sharing options...
Trixxeo Posted May 3, 2018 Author Share Posted May 3, 2018 20 hours ago, Scotts90 said: Some forceful tweaking may be required, a few tugs at the door frame can provide enough "adjustment" to aid fitment. Don't get too carried away though! Lol yeah I tired briefly but I wasn't tall enough.. stupid lift kit that I'm yet to ditch because I'm short! Quote Link to comment Share on other sites More sharing options...
neil110 Posted May 4, 2018 Share Posted May 4, 2018 In the past, when I had a twisted door, I had about 6 shims under 1 hinge to get it to close properly Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 4, 2018 Share Posted May 4, 2018 Just done a set of doors myself, the originals had a number of the plastic gasket type things packed under the hinges on the door part to obviously align the door up, go for it. Quote Link to comment Share on other sites More sharing options...
