reb78 Posted May 14, 2018 Share Posted May 14, 2018 The hub seal on the drivers side of the 110 is weeping slightly. Its the seal land thats likely at fault as I noted it was a little rough when i last had the hubs off. I was considering a speedi sleeve, but the stub axles arent actually that dear to buy and replace. Bearmach do a kit I think, but I cant identify which one i need for my 1989 110 (TD era, pre defender). Can anyone point me to the correct kit please? Quote Link to comment Share on other sites More sharing options...
western Posted May 14, 2018 Share Posted May 14, 2018 the stub axle is frc4320 page 420 of http://www.retroanaconda.com/landrover/parts_books/110/5_axles_suspension_steering_p398-471.pdf same age/model as my 110. are you in cornwall permanently now ? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 14, 2018 Share Posted May 14, 2018 I’ve just bought a replacement stub axle from EAC for my 90 (same as yours) as doing a hub seal every 15,000 miles is getting old - purportedly OEM so we’ll see how it is this weekend. I used OEM Bearmach ones on the 110 rear axle and they seemed good, though it’s not turned a wheel in anger yet so I reserve judgement! But they were nicely machined and the bearings were a good fit on them which is better than what I have read of Britpart ones. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 13, 2018 Author Share Posted June 13, 2018 Thanks for these links. James - did the stub axle come with the seal and bronze bush or did you need to order these separately? If thats the case, i think i only need the stub to axle gasket and a new hub seal. Bearings seem ok, so they can just get a grease unless its really bad practice not to do these at the same time? Ralph - Cornwall at weekends at the moment - so the 110 is doing 500 miles a week currently! 1 Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 13, 2018 Share Posted June 13, 2018 It came with the bush and seal installed already. Seems okay so far Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2018 Share Posted June 13, 2018 Quote Ralph - Cornwall at weekends at the moment - so the 110 is doing 500 miles a week currently! it's getting a lot of use then, better than having it sitting doing nothing, will have to meet up at some point Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 21, 2018 Author Share Posted June 21, 2018 Is FTC4785 the correct hub seal for a 1989 110? The part numbers in the book all appear to be superceded to FTC4785 but that seems to state from 1994 onwards. Not sure if that makes much difference? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 21, 2018 Share Posted June 21, 2018 Do you run your bearings in oil? if so you want the earlier RTC3511 I think it is, the seal with the extra lip. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 21, 2018 Author Share Posted June 21, 2018 I use grease in mine Ross. I might order an RTC3511 as well so i can compare them. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 21, 2018 Author Share Posted June 21, 2018 Grrrr. Put the whole order in and shop4autoparts just rang to say they don't have FRC4320 and wont be getting any more! You must have got the last one James! Quote Link to comment Share on other sites More sharing options...
