lol Posted February 26, 2019 Share Posted February 26, 2019 Haveing some furling issues on a carbed 3.5 v8 have changed the filter in the passenger front wheel arch but with the feed disconnected I get a very very weak dribble of fuel the electronic pump in front of rear passenger wheel arch makes a noise-is there a filter inside this? -is this the only pump? Any help appreciated! Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 26, 2019 Share Posted February 26, 2019 There may be a filter in the pump. Red spot pumps I've used in the past when running a V8 had a filter where the fuel intake to the pump was probably worth a check also could be a filter in the tank Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 26, 2019 Share Posted February 26, 2019 If it's a facet-style pump mounted on the chassis then yes it's got a filter inside it, you can still get them. It should fairly hose fuel out of an open pipe. Also worth checking it's getting a good voltage, if the wiring is crusty or connectors corroded / badly earthed that won't help. Quote Link to comment Share on other sites More sharing options...
walace58 Posted February 27, 2019 Share Posted February 27, 2019 Odd , I thought the fuel pumps were in the tank, my 94 and earlier Classic were both in the tank? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 27, 2019 Share Posted February 27, 2019 Some were, some weren't, it's an age thing - OP said his was on the chassis rail so I'm assuming it's original although I suppose someone could've had a knackered in-tank pump and just hung a Facet on the chassis rail for cheapness... if it's sucking through a dead in-tank pump that likely wouldn't help! Quote Link to comment Share on other sites More sharing options...
lol Posted February 27, 2019 Author Share Posted February 27, 2019 No you were correct facet type with a filter inside on the chassis leg,however I can only describe the out let pressure as a dribble so new pump on order (internal filter seems clean) Quote Link to comment Share on other sites More sharing options...
