kevin50 Posted April 29, 2019 Share Posted April 29, 2019 (edited) Im in a bit of a Dilemmas here . Im in the process of rebuilding 110, it has LT77 box mated to 300tdi disco engine, Now I did not buy this whole it was rolling chassis but did get most of parts all loose. Getting to the stage to put seatbox in but cant get things to match up. I have the original 200 tdi tunnels, but the seat box I got later is 300tdi, I tried 300 tunnels and they will at a push match up to box but the short gear stick wont move backwards unless I cut a bit out of the tunnel. The original 200 tunnels look perfect but they obviously wont match up to seat box, other then buy another 200 seat box would it be possible to change fronts,? that is if I can find a 200. First 3 photos 300tdi tunnels third 200tdi tunnel, forth 300tdi seat box. Once I figure it out all bits are going to get cleaned and painted before fitting. Insert other media.url Edited April 29, 2019 by kevin50 forgot to add Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 29, 2019 Share Posted April 29, 2019 You need to use a 200Tdi tunnel as your gearbox is in that position. So either adapt your 300Tdi seatbox or swap it for a 200Tdi one. I have a 200Tdi one somewhere which you’re welcome to if the logistics can be made to work. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 29, 2019 Author Share Posted April 29, 2019 Just now, Retroanaconda said: You need to use a 200Tdi tunnel as your gearbox is in that position. So either adapt your 300Tdi seatbox or swap it for a 200Tdi one. I have a 200Tdi one somewhere which you’re welcome to if the logistics can be made to work. Thank You Can the fronts be changed, as in taking the 300tdi front off mine and adding the 200 ??. they seem to be a separate panel riveted on to front of seat box. Where in Scotland are you Mate? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 29, 2019 Share Posted April 29, 2019 I don’t see any reason why not. To be honest the pattern is hardly complicated, so anyone semi-competent with a sheet of aluminium could make something up to give the correct flange. I’ll PM you regarding location. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 30, 2019 Share Posted April 30, 2019 I'm down in Oxfordshire with a converted seatbox if that's any use? It's just had the front panel of a 200tdi riveted over the Td5/300tdi opening (It's a Td5 seatbox that's had the box under the drivers seat removed and the tunnel flange modified. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 30, 2019 Author Share Posted April 30, 2019 3 hours ago, landroversforever said: I'm down in Oxfordshire with a converted seatbox if that's any use? It's just had the front panel of a 200tdi riveted over the Td5/300tdi opening (It's a Td5 seatbox that's had the box under the drivers seat removed and the tunnel flange modified. Have you got phots Mate, sounds just what I need Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 30, 2019 Share Posted April 30, 2019 I'll grab some pictures when I'm at the workshop later Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 30, 2019 Author Share Posted April 30, 2019 2 minutes ago, landroversforever said: I'll grab some pictures when I'm at the workshop later Thanks Mate Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 1, 2019 Author Share Posted May 1, 2019 (edited) Cant afford another box unless its cheap enough,so looking for a panel to swap over on my box, Please don't Laugh as I'm not much good at stuff like this but I made this tonight, if all else fails finding a spare bit I think this might just work. maybe should have made a little wider then it is. I used the old box to Mock Fit it.All holes line up right, but the hardest bit will be fitting it in the right place on to my box after taking the 300 off. Theirs a big gap to fill in as well. Edited May 1, 2019 by kevin50 forgot to add Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 1, 2019 Share Posted May 1, 2019 Bit more plate and some rivets and that’ll work fine. Carpets or mats will hide the joins. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 4, 2019 Author Share Posted May 4, 2019 Finally got seat box put together, everything lines up just about perfect, so will go ahead and fit it.Just a couple of questions before I start, First does the floor panel go Under the tunnels or other way round ? Second got this seal stuff with it, does this go on Every Join ?? 1 Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2019 Share Posted May 4, 2019 Quote Just a couple of questions before I start, First does the floor panel go Under the tunnels or other way round ? Second got this seal stuff with it, does this go on Every Join ?? the floor panels sit under the tunnel/adaptor panels. the seal strip should be applied to all panel lower face edges. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 4, 2019 Author Share Posted May 4, 2019 26 minutes ago, western said: the floor panels sit under the tunnel/adaptor panels. the seal strip should be applied to all panel lower face edges. Thank You, Does seal also go on the underside of floor and where tunnel joins bulkhead ?? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 5, 2019 Author Share Posted May 5, 2019 Think I’ve finally got everything lined up ready to bolt in. Haven’t got Tub Mounts yet. Will I still be able to bolt seat box to tub? Or should I wait till Tub is bolted In Properly Quote Link to comment Share on other sites More sharing options...
