RGK Posted May 9, 2019 Share Posted May 9, 2019 (edited) Hi, The wifes disco 1 has one more mot in it, then i'm planning to strip it for parts ie engine, axles, etc for my 90. Which left me with the conundrum what to do with the leftovers... the chassis and body. One thought was to chop the front end off to re-engineer into a trailer/ camper (as sketched attached). My questions are: 1. has anyone done this conversion and/ or towed a conversion like this? if so, how was it? is it to heavy? 2. am i better to cut the disco down from the A pillar or make it shorter by cutting from the B pillar? 3. Could i lighten the chassis? D1 1996 Dim's - Draft Layout 1.pdf Edited May 9, 2019 by RGK Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 9, 2019 Share Posted May 9, 2019 Very expensive to do properly, there are much better solutions out there, and add to the fact that it would need to go through an IVA before going on the road, it just doesn't make sense financially or practically. 1 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted May 10, 2019 Share Posted May 10, 2019 Looking at those measurements, would it not be too short to lay down in if you’re going ahead with using it as a camper trailer? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 10, 2019 Share Posted May 10, 2019 What bowie said. If you want a camping trailer buy a trailer and convert it. I'm planning to build a caravan based on a box trailer chassis to avoid the IVA issue. Mike 2 Quote Link to comment Share on other sites More sharing options...
