110 Salisbury diff oil seal
I've tried the search but didn't get any hits.
My 110's Salisbury rear axle output oil seal is leaking. Its a 1989 with a FA37****  VIN
The ancient LR Part Manual I have access to shows Part No AEU2515 - I believe there is a leather version (old) and *maybe* a rubber version (modern) - is this correct?  If so I can replace with the later seal and it will fit?
Any bear traps I need to be aware  of eg variations in output flange diameters or the like that might trip me up?
Thanks for any advice.
Thank you Reb. It was a bit confusing (!) but I think the options are:
1) Use leather original seal and (having marked flange & nut) redo until the marks match again super tight thus not bothering the crush tube and all that.
2) Replace with new flange kit which replaces exisiting flange/seal/nut and just crank up super tight.
Is there actually a newer rubber seal that replaces the leather version, using the existing flange?
20 hours ago, lo-fi said:
I believe Snagger used 160lb/ft. The crush tube deforms at ~250lb/ft, so it's tight enough without risking crushing the tube any more. I've done similar myself when swapping the flange out for the newer type of seal.
When you swapped, was it both flange and the seal, or did the seal retro-fit ok on existing flange?  And I might manage 160ft/lb lying on the road with my back against a tyre!
Yep, you have to swap both; the flanges are a different design. Definitely worth making up a piece of bar with a couple of bolts to pick up on the prop bolt holes, and make it long enough to wedge against the floor!
  • Like 2
It was about that, and certainly the principle of “tight enough to take out all slack and elasticity, but not tight enough to further crush the tube” is right.  Worked fine with no adverse effects.
Aye that little nugget of wisdom sunk in from reading another thread!
Thats reassuring. I'm always wary of over tightening (or not tight enough) something critical.
Thanks everyone.
  • 2 months later...
When replacing seal and flange its VERY important to undo axle breather from casing and clear all muck from both angle piece and pipe ever so easy to do and fixed my leak before i changed seal any way as it was 20years old. Mine was totally blocked with rusty oily muck.see brittanica restoration on u tube.
