Defender768 Posted January 29, 2020 Share Posted January 29, 2020 Hi Guys, My 90 has started pouring out white smoke on cold startup and sounds like she’s only running on 3 cylinders and then the 4th kicks in. Runs perfect after a few minutes and on startup once warm. Any ideas of where to start would be hugely appreciated. Quote Link to comment Share on other sites More sharing options...
crwoody Posted January 29, 2020 Share Posted January 29, 2020 Personally, I'd be checking the glowplugs first. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 29, 2020 Share Posted January 29, 2020 Bad spray pattern, low compression, retarded timing. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 29, 2020 Share Posted January 29, 2020 There is another thread on here with an identical start, that was probably due to 2 injectors needing a service. As said above glow plugs are an easy thing to check too. White smoke can be due to retarded timing, but how would it suddenly retard? That can only be timing belt related. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted January 29, 2020 Share Posted January 29, 2020 Tdi s rarely need glow plugs to start unless it is extremely cold. Mine is ok down to 2c this winter from personal experience. If there is ice I do allow the glow plug light to extinguish before starting. I would look to checking compression and possibly injectors. Quote Link to comment Share on other sites More sharing options...
Defender768 Posted April 13, 2020 Author Share Posted April 13, 2020 Thanks guys just got to the bottom of this found out it’s a bent Conrod... new engine time Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 13, 2020 Share Posted April 13, 2020 57 minutes ago, Defender768 said: new engine time why not put a new (used) conrod in ? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 14, 2020 Share Posted April 14, 2020 I've got a set of Rods sat in the Shed for a 300TDi. Your welcome to them for a few beer vouchers. An engine rebuild is a doddle, and less risk than buying a dog of a replacement. Quote Link to comment Share on other sites More sharing options...
Defender768 Posted April 15, 2020 Author Share Posted April 15, 2020 (edited) How easy is it to do ? Not much mechanical experience. 4th piston isn’t coming up high enough bores are also very glazed Edited April 15, 2020 by Defender768 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 15, 2020 Share Posted April 15, 2020 If you can hold a spanner and follow basic instructions then an engine rebuild is not particularly difficult in my opinion. Sounds like the block needs pulling out and giving a good going over. Where are you located roughly? Quote Link to comment Share on other sites More sharing options...
