300tditaffy Posted February 19, 2020 Share Posted February 19, 2020 Working my way through my recent purchase and the brakes are carp, the peddle is solid and you have to stand on the peddle to stop. Theres new pads and discs on the the rear and when the rain stops theres new pads and discs going on the front, i pulled the pipe off the servo and theres a good vac off the pump and the peddle feels the same with the pump disconnected am i right in thinking the servo is knackered. I got a spare servo off a 200 tdi will this fit Quote Link to comment Share on other sites More sharing options...
92a Posted February 19, 2020 Share Posted February 19, 2020 If you put your foot on the brake pedal then start the engine the pedal should go down another inch as the vacuum builds up , If I remember correctly, 1 Quote Link to comment Share on other sites More sharing options...
andy _1 Posted February 20, 2020 Share Posted February 20, 2020 Yup that's right Quote Link to comment Share on other sites More sharing options...
300tditaffy Posted February 20, 2020 Author Share Posted February 20, 2020 Just got to wait for some dry weather so i can change it Quote Link to comment Share on other sites More sharing options...
300tditaffy Posted February 26, 2020 Author Share Posted February 26, 2020 Problem solved, there was a big vac leak on the grommet whick holds the non return valve into the servo Quote Link to comment Share on other sites More sharing options...
steve b Posted February 26, 2020 Share Posted February 26, 2020 That's a nice cheap fix , good to hear it is sorted cheers Steve b Quote Link to comment Share on other sites More sharing options...
300tditaffy Posted February 26, 2020 Author Share Posted February 26, 2020 A few more cheap fixes i need Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 26, 2020 Share Posted February 26, 2020 55 minutes ago, 300tditaffy said: A few more cheap fixes i need It will NEVER happen! 🤣🤣 1 Quote Link to comment Share on other sites More sharing options...
300tditaffy Posted February 26, 2020 Author Share Posted February 26, 2020 I know i just live in hope, every defender ive had has had good money spent on it only to find the basics have been neglected big time Quote Link to comment Share on other sites More sharing options...
