Geojake Posted April 4, 2020 Share Posted April 4, 2020 Hi all, New to the forum with a 1989 90 200tdi that is getting all my attention during the coronavirus lockdown. Life could be worse. I want to fit a stage one series, twisted style, front to the the old girl. The kits that Twisted and Supertweaks do cost a lot of money for essential series light surrounds and a metal plate to cover the front of the light panel. The surround I can source but I’m struggling with the plate. I’m thinking about getting some replicas pressed but wondered if anyone knew how there are fixed to the landy, or had any knowledge of them at all? Links for reference and images below. https://www.twistedautomotive.com/store/product/stage-one-grille-set-workshop-fit https://www.supertweaks.com/land-rover/land-rover-defender/land-rover-defender-exterior-accessories/land-rover-defender-classic-stage-one-light-surrounds-pair Cheers Jake Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 5, 2020 Share Posted April 5, 2020 They'll be held on by the screws through the lights and the bezels, looking at them. Though it appears there are holes bottom left/top right that would pick up on standard Defender surrounds, they just haven't used them. Could be as it's just for demonstration, but it makes it look 'cleaner' than if secured properly as you would. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted April 5, 2020 Share Posted April 5, 2020 Why not use cut a flat plate to fit in the recess on the wing then fit your light surrounds. Personally I think this will look better and it doesn't need to be pressed. Oh and you can see the fixing holes in the picture that they haven't fitted screws to so they are using the light surround screws. Mike Quote Link to comment Share on other sites More sharing options...
Geojake Posted April 5, 2020 Author Share Posted April 5, 2020 Thanks all. I’m thinking about maybe trying it with the existing stock plastic surround, taking a dremmel to the Iip and seeing if it fits. I’m concerned it may be too thick, that is the issue. Good spot with the 4 corner holes. Agreed would be better to use the light recesses and the bezel surrounds. Will have a play and post some pics! Jake Quote Link to comment Share on other sites More sharing options...
neil110 Posted April 5, 2020 Share Posted April 5, 2020 (edited) Why do you need the plate? It is only there to cover a hole in the later type front ends. Presumably your 200 will not have such holes? Early: https://www.brit-car.co.uk/product.php/91496/0/front_wing_headlamp_panel_right_hand_front_series_111___defender_upto_vin_la Late: https://www.brit-car.co.uk/product.php/618873/0/headlamp_mounting_panel_right_hand_defender_from_vin_xa_on Edited April 5, 2020 by neil110 Quote Link to comment Share on other sites More sharing options...
paime Posted April 6, 2020 Share Posted April 6, 2020 I can't believe the cost of those light surrounds! Utter madness!! Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 6, 2020 Share Posted April 6, 2020 (edited) If you think these are bad, don't look for aluminum billet windscreen brackets, and I've seen £400 door hinges. Edited April 6, 2020 by ThreePointFive Quote Link to comment Share on other sites More sharing options...
Geojake Posted April 6, 2020 Author Share Posted April 6, 2020 (edited) On 4/5/2020 at 3:46 PM, neil110 said: Why do you need the plate? It is only there to cover a hole in the later type front ends. Presumably your 200 will not have such holes? Early: https://www.brit-car.co.uk/product.php/91496/0/front_wing_headlamp_panel_right_hand_front_series_111___defender_upto_vin_la Late: https://www.brit-car.co.uk/product.php/618873/0/headlamp_mounting_panel_right_hand_defender_from_vin_xa_on Neil, I don’t need them, but think they finish off the front quite nicely. I also have a lot more screw holes in from various previous owners that have don’t all sorts, I can fill these holes but would be easier to blank them off with that plate. I will try without and see what I can get away with but was worth asking in here. I’ll try and cut some out anyway as a trial Cheers Jake Edited April 6, 2020 by Geojake Quote Link to comment Share on other sites More sharing options...
Geojake Posted April 6, 2020 Author Share Posted April 6, 2020 3 hours ago, paime said: I can't believe the cost of those light surrounds! Utter madness!! Madness!! Especially when after a bit of searching I can get 2 light surrounds brand new for 25 quid. As I am finding out, anything associated with and marketed for a Defender costs $$$$ Quote Link to comment Share on other sites More sharing options...
paime Posted April 6, 2020 Share Posted April 6, 2020 Does anyone have any spare door hinges or windscreen brackets lying around they don't need any more? Even better if they've got the pins removed and are in 2 parts. I'd like to get a cost from a local fab shop here i know for billet aluminium replacements purely out of interest. You'll need to take some images for me in a certain way so i can create a 3D model but it's easy stuff. Quote Link to comment Share on other sites More sharing options...
neil110 Posted April 10, 2020 Share Posted April 10, 2020 On 4/6/2020 at 3:02 PM, paime said: I can't believe the cost of those light surrounds! Utter madness!! especially when you can get them for this price. https://www.brit-car.co.uk/product.php/79467/0/headlamp_surround_bezel___series_111 Quote Link to comment Share on other sites More sharing options...
