DiveTramp Posted August 8, 2020 Share Posted August 8, 2020 Hi all, a new to me, One Ten Defender County Stationwagon, 1989 vintage, has found it's way to my 4 post. It's had a galvy chassis fitted back on 2010, but the useless "fitters" didn't set it up with ANY spacers or rubber body mounts, at all! I've trawled the internet but can't fond any videos or info on exactly where these things should go. There is a definite dip in the roof And a definite curve in the bottom sill too. This means the doors do not fit well at all so, I'm hoping you guys could tell me what should go where. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 8, 2020 Share Posted August 8, 2020 Item #2 looks about right; https://www.lrworkshop.com/diagrams/land-rover-defender-body-chassis/body/rear-body-lower-mountings_52716 Quote Link to comment Share on other sites More sharing options...
DiveTramp Posted August 8, 2020 Author Share Posted August 8, 2020 5 minutes ago, FridgeFreezer said: Item #2 looks about right; https://www.lrworkshop.com/diagrams/land-rover-defender-body-chassis/body/rear-body-lower-mountings_52716 I've got the rubber mounting pieces, and think I can see where they go, it's the locations of the metal spacers I'm seeking. The C pillar is also a botch job. Its simply two pieces of 40mm x 25mm welded in. From what I've seen online, the angular C pillar part tapers as it meets the sill. Is this correct? Anyone have the dims for this piece? I know I'm going to have to cut it loose as I jack up and reset the tub. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted August 8, 2020 Share Posted August 8, 2020 In the last picture there should be some long M8 bolts through the body crossmember into the bracket welded to the chassis directly above the rear trailing arm bush. 1 Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2020 Share Posted August 8, 2020 Pic 1, m6 bolts through bottom to outrigger 4 on each bracket, top vertical should have 2 bolts through to body on each bracket Pic 2 rubber pad missing from the rear bracket & long bolts missing from 2nd row under floor cross member to chassis bracket. this might help With ref to Pic 1 With ref to Pic 2 reply rubber pad locations under loadbay floor above photo's copied from my chassis change thread here https://forums.lr4x4.com/topic/85416-new-chassis-for-my-1989-110/page/10/#comments 1 Quote Link to comment Share on other sites More sharing options...
DiveTramp Posted August 8, 2020 Author Share Posted August 8, 2020 That's awesome. Thank you all. I thought there ought to have been some bolts on that crewmember, I can see the threads of the captive nuts. I think I'll run a tap through them first tho... You wouldn't think this chassis swap was done by a professional garage, would you? Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2020 Share Posted August 8, 2020 The cross member bolts are bolts/nuts, with the body fitted the bolts have to be head facing down as you won't get them in from the top. I agree the chassis change looks bad for a garage, wonder if its the first one they have done. 1 Quote Link to comment Share on other sites More sharing options...
DiveTramp Posted August 15, 2020 Author Share Posted August 15, 2020 I think it must have been. Today I discovered the mounting brackets for side walls (where the windows are) have been fitted on the top rather that the bottom. This has been pushing the sidewall out by about 5mm. Are there any pics of the correct nut/washer/threaded rod/body/washer/nut combination that bolts the doorpost end down to the tub? I think they've screwed that up too as the spacing at the top of the door is quite small and not square. Quote Link to comment Share on other sites More sharing options...
western Posted August 15, 2020 Share Posted August 15, 2020 This will help http://www.retroanaconda.com/landrover/2010/02/land-rover-defender-110-parts-book/ I haven't had the interior side trim off my 110, so would like to say which way the bolts fit, but the parts book link will give you a good start. there maybe some good photo's in retroanaconda's 110 rebuild thread too. 1 Quote Link to comment Share on other sites More sharing options...
