western Posted October 25, 2020 Share Posted October 25, 2020 its a low oil pressure light, switch in the yellow ring in pic attached the bigger unit upper left is the sensor for oil pressure gauge. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 25, 2020 Author Share Posted October 25, 2020 Argh I see so in my filter head how many holes should I have im guessing I need 3 then. 1 for temp gauge, 1 for pressure gauge, and the last for existing dash light Quote Link to comment Share on other sites More sharing options...
western Posted October 25, 2020 Share Posted October 25, 2020 The low oil pressure light switch & gauge sensor use the same hole, as you can see in that photo, the oil temperature sender lives in the hole on the upper forward face as shown in the photos in the linked thread. I'm working 12 hour days this week so may not reply until I get home, but will try to look in during the day. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 25, 2020 Author Share Posted October 25, 2020 Lol sorry for stalking😂 I can probably manage from the info you provided so far still halfway through fitting alarm at minute. So it may not happen this week. cheers Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2020 Share Posted October 26, 2020 No problem with you asking questions Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 26, 2020 Author Share Posted October 26, 2020 6 hours ago, western said: No problem with you asking questions That’s good 😂 I got plenty more to come.. lol .. alarm fitting is testing my little brain Cheers Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2020 Share Posted October 26, 2020 I can't help with that, so you'll have to ask everyone else on here Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 26, 2020 Author Share Posted October 26, 2020 No problem.. I got it nearly figured. It’s just the immobilising part. it’s got 3 x immobilisation points 1 of which says to go to engine cut off (max 20a) that’s where I’m stuck with know nothing about amps etc Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2020 Share Posted October 26, 2020 Engine cut off I think would be the fuel stop solenoid on top rear of the injection pump. thats the only item that shuts the fuel off to stop the engine. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 27, 2020 Author Share Posted October 27, 2020 22 hours ago, western said: Engine cut off I think would be the fuel stop solenoid on top rear of the injection pump. thats the only item that shuts the fuel off to stop the engine. Cool .. I’ll tap into that I guess then. Assuming it will be less than 20a ? Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2020 Share Posted October 27, 2020 No idea, only because I've never measured the amp load of the fuel shutoff solenoid. 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 27, 2020 Author Share Posted October 27, 2020 Nice one Ralph. nothing in post today by the way.. not that I would of been out there in this rain 👍 Quote Link to comment Share on other sites More sharing options...
ballcock Posted October 27, 2020 Share Posted October 27, 2020 On 10/26/2020 at 8:35 PM, Chambo110 said: No problem.. I got it nearly figured. It’s just the immobilising part. it’s got 3 x immobilisation points 1 of which says to go to engine cut off (max 20a) that’s where I’m stuck with know nothing about amps etc The stop solenoid uses a lot less than 20 amp, but if your immobiliser just interrupts this supply I wouldn't bother as a common theft method is to just run a 12v supply direct from the battery to the solenoid. I would consider fitting another solenoid out of site for the immobiliser to operate. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 27, 2020 Author Share Posted October 27, 2020 3 minutes ago, ballcock said: The stop solenoid uses a lot less than 20 amp, but if your immobiliser just interrupts this supply I wouldn't bother as a common theft method is to just run a 12v supply direct from the battery to the solenoid. I would consider fitting another solenoid out of site for the immobiliser to operate. Hmmm interesting. I do have another 2 points that the immobiliser can do. What would you suggest ? Quote Link to comment Share on other sites More sharing options...
ballcock Posted October 27, 2020 Share Posted October 27, 2020 22 minutes ago, Chambo110 said: Hmmm interesting. I do have another 2 points that the immobiliser can do. What would you suggest ? Being a clockwork diesel there is very little electrically you can do other than the fuel supply, hopefully somebody else may have more suggestions. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 29, 2020 Author Share Posted October 29, 2020 On 10/27/2020 at 10:09 PM, ballcock said: Being a clockwork diesel there is very little electrically you can do other than the fuel supply, hopefully somebody else may have more suggestions. Could I do starter motor? No ideas when it comes to power loads etc. I do have other levels of security, it’s all about slowing them down until I can let the dog out 🐕 Quote Link to comment Share on other sites More sharing options...
monkie Posted October 29, 2020 Share Posted October 29, 2020 1 hour ago, Chambo110 said: Could I do starter motor? No ideas when it comes to power loads etc. I do have other levels of security, it’s all about slowing them down until I can let the dog out 🐕 Sounds probable, maybe the tracer wire from the starter relay? What ever you do, keep detailed notes for later fault finding years down the line. You might think you'll remember but I bet 5 years down the line you won't! Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted October 29, 2020 Author Share Posted October 29, 2020 23 minutes ago, monkie said: Sounds probable, maybe the tracer wire from the starter relay? What ever you do, keep detailed notes for later fault finding years down the line. You might think you'll remember but I bet 5 years down the line you won't! Good point... I don’t remember this morning so it’s a good idea 👍 1 Quote Link to comment Share on other sites More sharing options...
