Ivor Posted November 7, 2020 Share Posted November 7, 2020 Hi, have got a set of these on my 110, , they have a metal cage on inside of bowl, do these need to be there as they seem to be shielding more light from already poor light Quote Link to comment Share on other sites More sharing options...
miketomcat Posted November 7, 2020 Share Posted November 7, 2020 Yes it's to create the required light pattern using the reflector. If it wasn't there you would need a patterned lens. I find crystal lights ok so I would suggest your bulbs are passed there best you'd be surprised how much better a new set are especially if you go to night breakers. Mike Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted November 7, 2020 Share Posted November 7, 2020 I'll second Night Breakers, especially in conjunction with good quality wiring delivering a healthy voltage to the bulbs. Quote Link to comment Share on other sites More sharing options...
ballcock Posted November 8, 2020 Share Posted November 8, 2020 On 11/7/2020 at 12:05 PM, Ivor said: Hi, have got a set of these on my 110, , they have a metal cage on inside of bowl, do these need to be there as they seem to be shielding more light from already poor light Welcome to the forum. Are your lights still on the original wiring? If so consider an upgrade to using relays as this will improve them considerably. If you do a search on the forum you will find a few topics. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted November 9, 2020 Share Posted November 9, 2020 ^^^ also ensure that you have, not good, but excellent earths. Voltage drop over the earth connection does not help you see. BTW welcome to the forum. Mike Quote Link to comment Share on other sites More sharing options...
simonpelly Posted November 9, 2020 Share Posted November 9, 2020 Also another big fan of the Night Breakers. Here's a link to dedicated wiring we put on our Defender. https://pellylandroverdefender.blogspot.com/p/headlights.html Enjoy! Simon... Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted November 9, 2020 Share Posted November 9, 2020 Remembered to check mine - Wipac that were installed around 2010; No metal cage around the bulb, but the reflector has a vertical ribbed pattern to focus the beam. The metal cage may be linked to the design of reflector. Quote Link to comment Share on other sites More sharing options...
