Crystal lights
Ivor
Yes it's to create the required light pattern using the reflector. If it wasn't there you would need a patterned lens. I find crystal lights ok so I would suggest your bulbs are passed there best you'd be surprised how much better a new set are especially if you go to night breakers.
Mike
On 11/7/2020 at 12:05 PM, Ivor said:
Hi, have got a set of these on my 110, , they have a metal cage on inside of bowl, do these need to be there as they seem to be shielding more light from already poor light
Welcome to the forum. Are your lights still on the original wiring? If so consider an upgrade to using relays as this will improve them considerably. If you do a search on the forum you will find a few topics.
