Simon_CSK Posted October 10, 2021 Share Posted October 10, 2021 I have just come to remove the wheel on one of my cars and the locking wheel nut is huts spinning. Either the thread is stripped or more likely the splines on the hub are stripped either way the result is the same. My first thought was to drill it out but my drilles are not making a dent in the wheel nut, is this some kind of hardened steel? Ideas please. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted October 10, 2021 Share Posted October 10, 2021 Disc or drum brake? Can you get the hub off complete with wheel? Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted October 10, 2021 Share Posted October 10, 2021 You could try one of these: https://taitatools.com/ Mike Quote Link to comment Share on other sites More sharing options...
smallfry Posted October 10, 2021 Share Posted October 10, 2021 Hardened ? Most likely. After all, they are not meant to be easy to remove. If you have to drill, try Toolstation for some cobalt drill bits. Start off with about 4mm and make larger if it works. Use cutting oil to keep it cool. maybe get someone to spray it on while you drill. Just a squirt every few seconds. Good luck ! However, when this happened to a friend (he lost the key socket) we ended up having to cut the wheel and tyre off with an angle grinder. Had no drill though, and he was in a hurry, and has even less patience than I do Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted October 10, 2021 Author Share Posted October 10, 2021 I turns out that the key is made in 2 parts. The main body and a band for the interlock. All other Land Rover wheel nut keys I have are one piece casting. The lock is spinning in the key so have ordered a new key on Ebay. What idiot designed a two piece wheel lock key!! Grrrr Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted October 11, 2021 Share Posted October 11, 2021 While you are waiting, if the security key is not hardened, you could try drilling through the side wall of the security key, tap the hole and thread a bolt into the recess in the security nut. This may prevent the key turning. If it does, you've gained a day or two, but if not, wait for the new key to arrive! Mike Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted October 11, 2021 Author Share Posted October 11, 2021 1 hour ago, Troll Hunter said: While you are waiting, if the security key is not hardened, you could try drilling through the side wall of the security key, tap the hole and thread a bolt into the recess in the security nut. This may prevent the key turning. If it does, you've gained a day or two, but if not, wait for the new key to arrive! Mike Thanks Mike. I did think about trying to weld it but couldn't find my welder. I know I have put it safe somewhere which means it will turn up in the most unlikely place I can think of. Quote Link to comment Share on other sites More sharing options...
