Paddy_SP Posted January 20, 2022 Share Posted January 20, 2022 Having got to the matter of rebuilding the rear side doors, I was seriously unimpressed to discover that the vertical divider bars (the bits that separate the two pieces of glass) were FUBARed. I did know it when I removed them, but as they've been hiding in a pile for more years than I care to remember I'd completely forgotten. I was even more unimpressed when I found out how much new ones were (£94 the pair). I would have made some new ones, but after examining the complicated extrusion they're made from, I decided that life was too short... Anyway - I've got them loosely in place, but without having an intact door to refer to, I thought it'd make sense to ask here just how they should be fixed in place. Is it with a screw at the top and a bolt at the bottom? Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted January 28, 2022 Author Share Posted January 28, 2022 Surely somebody on here must know how this part is fixed in place? Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 28, 2022 Share Posted January 28, 2022 if nobody knows the answer , i'll see if i can dig out a door to see how they attach . (i assume you looked at the parts diagram) Quote Link to comment Share on other sites More sharing options...
western Posted January 28, 2022 Share Posted January 28, 2022 I can't see any screws securing that strip in place, so I would suggest the glass & runners keep it in the door, there is a lower metal bracket below the small glass, thats the only bit other than the plastic channels & weather seals. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted January 28, 2022 Author Share Posted January 28, 2022 (edited) Thank you, Gentlemen - the bit that's most confusing me is that there's a screw hole at the top (it's hidden inside the channel, so is far from obvious), but it's stepped back from the door frame, so one has to assume that something goes in between the two (the parts list didn't help there!). Without knowing what that something is, I can't get an exact vertical location, and so daren't bond it in place until I know... Edited January 28, 2022 by Paddy_SP Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 3, 2022 Share Posted February 3, 2022 (edited) Sorry I missed this question. I replaced both doors a couple of years ago and have a few photos. That trim piece does screw up into the top of the door. Looking at my pics there's no vertical spacer and I don't remember one. Just be sure you have it in the correct orientation so that it does push up correctly. The horizontal position is defined by the fixed glass pane and the runners around that. Get that in first and then the long piece between the two glass panes is secured at the top and lower down. As you can see I hesitated as to the best position for the short runner. I removed it from the bottom of the pane where it had suffered greatly from water but I think I switched it and fitted the new one at the top. Edited February 3, 2022 by Peaklander Reloaded first pic as it wasn't fully displayed - why does that happen? Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 6, 2022 Author Share Posted February 6, 2022 Ooh - just seen this - many thanks indeed! Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 6, 2022 Author Share Posted February 6, 2022 So - having referred to your photos, I get most of it, but what is meant to locate the bottom sealing piece (the bit circled in red in the photo), that is, what stops it just dropping down inside the door? Whereas the originals seem to have been constructed from one length with vee cuts at the corners, the kit I bought from SP Panels is simply made up of four separate lengths. As there are absolutely no instructions though, I'm left scratching my head! There's a projection that presumably locates it at one end, but nothing at all at the other, so unless I bond it to the glass, there's nothing to hold it in place. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 6, 2022 Share Posted February 6, 2022 Refer to my photo above, two pics actually, as it messed-up when I posted then I didn't look again before the edit timer had expired. You can see the very rusty support bracket. It sits on that. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 6, 2022 Author Share Posted February 6, 2022 Ah - thank you - I wondered what that was - I'll have to dig some stainless out and make one! Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 6, 2022 Share Posted February 6, 2022 I've found another pic - it's hiding there behind the cross piece on the old door. I don't know why I have no finished pics. I did paint it, honest. Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 6, 2022 Author Share Posted February 6, 2022 Brilliant - thank you so much - at least I now know what to go trawling for in all the discarded bits boxes to get my template! Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 6, 2022 Author Share Posted February 6, 2022 I'm much happier now - thanks to your help I now know what two previously unidentified bits of rusty metal are, and if all goes to plan will get my doors assembled at last. They were lying at one end of the bench where I've laid out all the door parts waiting for an until now unknown use. Despite the fact that they're the victims of protracted corrosion, there's enough left to get all the necessary dimensions, so it looks as though later this afternoon I'll be spending some time with the guillotine and folder! 1 Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted February 7, 2022 Author Share Posted February 7, 2022 Well - I found some stainless of a suitable thickness (2 mm) and hacked it about until I had two replacement supports. I think they look a little healthier than the original! Quote Link to comment Share on other sites More sharing options...
