Green Bob Posted June 4, 2022 Share Posted June 4, 2022 Toying with the idea of adding flamestart to the 110. Does anyone know if the rear face of the 200tdi inlet manifold has enough thickness to be drilled and tapped?(Defender engine, not retrofitted Disco.) It seems the ideal location to install the plug. Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 4, 2022 Share Posted June 4, 2022 I've got a 1/8npt fitting tapped into the manifold just before the turbo, works ok. Quote Link to comment Share on other sites More sharing options...
hurbie Posted June 5, 2022 Share Posted June 5, 2022 why do you need a flamestart on a 200tdi ? .... mine starts without glowing al the way down to minus 5 celcius . below that i just use the normal glowplugs for like 10 seconds ... Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 5, 2022 Share Posted June 5, 2022 That was my question too^^^ mine will start in minus figures with no glow plugs. Quote Link to comment Share on other sites More sharing options...
