kevin50 Posted July 15, 2022 Share Posted July 15, 2022 Anyone fitted one of these before , Aint got a clue of how they join together, you would think there would be instructions with them.Anyone fitted one of these ? Sender unit - all SWB and LWB tanks with 6 screw fitting - Paddock Spares Quote Link to comment Share on other sites More sharing options...
DC_ Posted July 16, 2022 Share Posted July 16, 2022 I fitted a new tank and a new sender. It started leaking diesel when i Topped up the tank. it turned out I hadn’t tightened the locking ring enough. So a long screw driver and chapped it to the right more and bingo. hope this video helps you. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted July 16, 2022 Author Share Posted July 16, 2022 Thanks mine is a series with the 6 bolts in the top. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 17, 2022 Share Posted July 17, 2022 The hook rod goes round the float. You need to join that rod to the sender rod, but they will probably need adjustment so that the float drops to the bottom of the tank, but doesn't foul on the side wall, when the tank is full. Use a bog standard electrical choc block (other suppliers are available). https://www.screwfix.com/p/16a-12-terminal-terminal-strips-10-pack/91532?tc=KB5&ds_kid=92700055281954475&ds_rl=1249401&gclid=CjwKCAjw5s6WBhA4EiwACGncZW2IBxdkfFs5spYfCHWrq6RNWNeoTyu4or4Tr6h9c4XgrlDSxIMdsxoCxNkQAvD_BwE&gclsrc=aw.ds Cut one segment off and remove it from the plastic. You can then use that to join both rods - overlap them through the connector to start with. Small torch to look into the tank and some thread round the rod and trial and error is the way to go. Once you have got the rod length right, you can trim off the excess. They used to come all assembled with a fixed rod length..... Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted July 17, 2022 Share Posted July 17, 2022 I endorse the comment by Simonb, but I note you have (had) several S2 related queries running. I'd suggest overall you join the Series 2 Club. There is an active Forum, but, if you join, there are a load of technical publications you can access and down load, both Workshop and Parts manuals. Circuit diagrams are included; the Webmaster also creates 'easy to read' variations for people 'troubled' by standard wiring diagrams. Regards. Quote Link to comment Share on other sites More sharing options...
