D12MUD Posted January 25, 2007 Share Posted January 25, 2007 I have a 110 with a 200 tdi rebuilt engine that runs like a dream! one problem the oil light periodical comes on for a few seconds when breaking sharply or turning with a bit of speed there is more then enough oil! the filter is new any suggestions ! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 25, 2007 Share Posted January 25, 2007 Try changing the sender and see if that fixes it, it may be just over-sensitive to oil pressure fluctuations. 300Tdi senders are useless, I have had about 10 new ones in my 90 under warranty because they break as soon as they get wet. 200Tdi ones are better but it is a relatively cheap and easy place to start just to rule it out! Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 25, 2007 Share Posted January 25, 2007 What's the mileage on the engine? Quote Link to comment Share on other sites More sharing options...
D12MUD Posted January 25, 2007 Author Share Posted January 25, 2007 Try changing the sender and see if that fixes it, it may be just over-sensitive to oil pressure fluctuations. 300Tdi senders are useless, I have had about 10 new ones in my 90 under warranty because they break as soon as they get wet. 200Tdi ones are better but it is a relatively cheap and easy place to start just to rule it out! [/quo Thanks i will try this later today regards chris Quote Link to comment Share on other sites More sharing options...
D12MUD Posted January 25, 2007 Author Share Posted January 25, 2007 What's the mileage on the engine? Hi Steve the engine had a complete rebuild 6,000 mils ago regard Chris Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2007 Share Posted January 25, 2007 clean the spade terminal on the switch & tighten the wire connection by giving it a squeeze with pliers, it sorted mine out. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 25, 2007 Share Posted January 25, 2007 How much oil is plenty? Just that the dipstick tube may have been fitted too far in and give a false reading. Try draining the oil and the re-filling with the correctly measured amount so that you are certain. The symptoms are classic low oil. Chris Quote Link to comment Share on other sites More sharing options...
D12MUD Posted January 26, 2007 Author Share Posted January 26, 2007 How much oil is plenty? Just that the dipstick tube may have been fitted too far in and give a false reading. Try draining the oil and the re-filling with the correctly measured amount so that you are certain. The symptoms are classic low oil.Chris thanks I THINK I WILL TRY THIS REGRDS CHRIS Quote Link to comment Share on other sites More sharing options...
