steve b Posted March 15, 2023 Share Posted March 15, 2023 I have a late Puma 90 csw in at the moment and the client has asked about adding moulded rubber/foam composite mats for the rear wheel boxes. Currently no mats at all in this area, just rubber centre floor mats. It has the factory forward facing seats either side in the rear. Any recommendations for decent quality moulded wheel box sound deadening? There is also a small diesel leak to the front OS of the fuel tank, not enough to drip though, see pic. I'm assuming this is on the return somewhere as obviously the supply is under pressure. Is there a common failure causing this before I dig ant further? Thanks Steve Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 15, 2023 Share Posted March 15, 2023 The breather and filler pipes are common leak points, through perishing rubber. There is a factory rubber mat that covers the rear tub floor and wheel boxes. No foam deadening to my knowledge, it’s just a liner really. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 15, 2023 Author Share Posted March 15, 2023 Thanks James, You wouldn't happen to know the part no. for the factory rubber mats would you ? I'll look into the diesel leak with that in mind. Steve Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 15, 2023 Share Posted March 15, 2023 I think it’s STC4629 Quote Link to comment Share on other sites More sharing options...
steve b Posted March 15, 2023 Author Share Posted March 15, 2023 Indeed it is - thanks, I'll look into availability. Steve Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 16, 2023 Share Posted March 16, 2023 Have a look for the diesel leak being the tank breather roll over 1 way valve... although never done one on a 90, I've done x3 on 110's. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 16, 2023 Author Share Posted March 16, 2023 That was also mentioned when I searched t'web, I'll look at it when it's back for tyres soon, thanks for confirming the web search. Steve Quote Link to comment Share on other sites More sharing options...
fmmv Posted March 17, 2023 Share Posted March 17, 2023 Slight thread hijack, sorry, but my daughter has just bought a 2013 90. It has only done 29000 miles, and looks generally very good. Is there anything else apart from the useful stuff above I should look out for? I am used to 300tdis. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 17, 2023 Author Share Posted March 17, 2023 Don't delay between draining engine oil and refilling. 10min max. to avoid oil pump priming issues. Synthetic oil too. Keep an eye and ear on the wheel bearings for any play or bearing noise. All the usual corrosion risk area's are still there so you'll know where to look out for white powder or red flakiness Steve Quote Link to comment Share on other sites More sharing options...
fmmv Posted March 17, 2023 Share Posted March 17, 2023 (edited) Thanks for the tips, and re corrosion, I know only too well...already dealing with the first 'canujust' - a towbar Edited March 17, 2023 by fmmv Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 17, 2023 Share Posted March 17, 2023 11 hours ago, steve b said: Don't delay between draining engine oil and refilling. 10min max. to avoid oil pump priming issues. Is that something LR or Ford specified? Not heard it before! Quote Link to comment Share on other sites More sharing options...
steve b Posted March 17, 2023 Author Share Posted March 17, 2023 From what I've been told it's Tdci specific, there are other vehicles within the general motor trade that suffer from the same issues. This is my first Tdci too, I'm more usually buried in Series or the earlier 90/110/Defender end of things. Steve 1 Quote Link to comment Share on other sites More sharing options...
