Defender V8 Clutch Issue
32 minutes ago, steve b said:
That is a very tidy looking job, hope it's sorted and I'm not in the least envious that you are in the mountains around La Paz working a V8 :)
If you can post some pic's of your "day to day" scenery I for one would enjoy them.
Steve
Thank you! Off topic I have attached a couple of photos as requested.
Del
  • Like 1
  • Thanks 2
11 minutes ago, Retroanaconda said:
My Tdi used to have a soft clutch pedal the first few presses after a motorway run on a hot day - same problem I reckon.
That is what had me foxed. The pedal was always firm until it wasn´t when the fluid ran out! Which fortunately only happened once just outside where I live. What I cannot understand is where the fluid disappeared to. We are not talking gallons I appreciate, but over time well over a quarter of a litre of hydraulic fluid has gone walkabout and there is not a trace of it anywhere.
del
del
Boiled off through radiant heat and altitude is how I arrived at a heat shield.
Thanks for the pic's , by all means keep them coming over time. Very interesting terrain and so good to see a Real Land Rover in it's home environment.
Happy trails
Steve
Happy trails
Steve
Agreed. A few more off topic photos for you. Many thanks for your help.
Del
  • Thanks 1
That heat shield and the mountings are elegant. I had a concern that my slave cylinder and pipe was getting cooked by the manifolds that were even closer than your pipes. I wrapped the cylinder in a malleable shield material and fed the pipe through a heat resistant sleeve designed more for wiring. Your solution is much nicer. I'd copy it if I had facilities.
