muddy Posted June 1, 2023 Share Posted June 1, 2023 I think i'm right in saying that no other winch apart from some of the uber expensive ones share the same mounting pattern? Are they a decent winch even in standard form? I have just bought a 'challenge truck' to rebuild into a trials/off road toy and am pondering what to do with the front 8274 cradle and rear D44 crossmember. Are they worth the premium they command? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 2, 2023 Share Posted June 2, 2023 They are good winches however I've never been able to justify the extra they command. Their main benefit is speed and potential for bigger drum. So if your just dragging yourself and others out on greenlanes and playdays just about any winch will do, I've had an EP9 and now an X9 both very good winches. Whereas if your doing competition an 8274 is a good start but you'll likely disappear down the upgrade hole. Mike Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 2, 2023 Share Posted June 2, 2023 <shallow comment> They do look cool though don’t they ! </shallow comment> Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 2, 2023 Share Posted June 2, 2023 1 hour ago, Anderzander said: <shallow comment> They do look cool though don’t they ! </shallow comment> Whilst looking eminently nickable. They are 'only' 8000lb out of the box, which may influence depending on weight of vehicle and usage. You could always adjust the current setup with welder and grinder to suit the much better value lowline winches, shouldn't take too long. Quote Link to comment Share on other sites More sharing options...
muddy Posted June 2, 2023 Author Share Posted June 2, 2023 Thanks chaps, I think I'll mod the rear to take a low line and ponder over the front. I have seen a couple of ready to run 8274s with rope on for £800-1000 which when compared to buying a 'good' lowline and then time, effort and money altering brackets closes the gap somewhat. Quote Link to comment Share on other sites More sharing options...
ped Posted June 2, 2023 Share Posted June 2, 2023 i had one and didn't think it was anything special ,that said my use for a winch often inc's pulling tree's over lowering etc so i prefer a worm gear winch which whilst is slow it doesn't rely on brake blocks i'm at present thinking of not fitting my h14 hydraulic and putting my old electric winch on which is a pierce wrecking winch Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 8, 2023 Share Posted June 8, 2023 If anyone wants a more powerful winch … https://www.facebook.com/marketplace/item/1710509636036651/? 1 Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 9, 2023 Share Posted June 9, 2023 @muddy the standard 8274 boltpattern is the same pattern as low line winches, i do have a comeup lowline with there wide drum conversion which makes it the same bolt pattern as a +3" width 8274 Quote Link to comment Share on other sites More sharing options...
muddy Posted June 10, 2023 Author Share Posted June 10, 2023 17 hours ago, RedLineMike said: @muddy the standard 8274 boltpattern is the same pattern as low line winches, i do have a comeup lowline with there wide drum conversion which makes it the same bolt pattern as a +3" width 8274 Thanks, I will bare that in mind. im guessing you just mount the low line feet first agains the face on the 8274 winch tray. The D44 rear crossmember has an offset slot for the rope so im just mocking up a husky I have to fit in there. more thank likely turn into a massive job but easier now than when the tubs on. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted June 10, 2023 Share Posted June 10, 2023 yeah just mount the lowline feet forwards / outwards, how do you mean the slot is offset? im assuming its at the bottom of the bolt spacing? Quote Link to comment Share on other sites More sharing options...
muddy Posted June 10, 2023 Author Share Posted June 10, 2023 The slot for the fairlead on the rear is offset to the RH, the front tray is central. not the best pic but you can see it here. Quote Link to comment Share on other sites More sharing options...
