Sigi_H Posted September 5, 2023 Share Posted September 5, 2023 Hi all. Since my car is a MY83 OneTen new sill rails and C-Posts are more than necessary. B-Posts are really in good condition and in original colour. I'd like to leave them. There are some kits around, but I still have some questions. One of my wishes is to have a better side impact protection. SP-4x4 offers galvanized 3 mm rails (instead of 2mm), which I like to fit. With Tree Sliders mounted it will even be better. But why not replace the rails with Tree Sliders? Does anybody know of even better sill rails? I can imagine, that a rectangular tube instead of the U-shaped original is possible on this place. Another question is, are the B-Posts spot welded? Then it would be easier to leave them in place and only do the rails and C-Posts. What are the exact dimensions of the original Sill rails? So my questions are: Are there possibly more massive Sill rails for side impact protection? Are there Sill rails combined with Tree Sliders? Are the B-Posts spot welded? What are the exact dimensions of the original Sill rails? Any further idea is appreciated Sigi Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 5, 2023 Share Posted September 5, 2023 I'd have thought the sill rails are academic in a side-impact if you're got rock sliders? When I rebuilt the 109 you couldn't buy the B-pillar/sill piece so I re-made the sill in 25mm box section and bolted the remains of the B-pillar to it. Then Dirtydiesel made me rock sliders which will outlive a nuclear apocalypse... But if something hits you sideways in a Series/Defender your brain's going to be splattered round the hard pointy insides of the cabin anyway - there's no curtain airbags or anything after all. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 5, 2023 Share Posted September 5, 2023 I would have thought that fabricating the sill rail out of some decent RHS would provide a decent solution. 2mm vs 3mm on the original design is probably neither here nor there in a side impact situation? I would imagine box would be better but it does introduce another rot point. Should be fairly simple as its just a straight piece from the A pillar to C pillar. B pillars are spot welded I think - pretty sure I can see the spot welds through the paint a the bottom of mine. C pillars were so I think B will be the same. I am considering the galv option from YRM for when i rebuild mine. Quote Link to comment Share on other sites More sharing options...
western Posted September 5, 2023 Share Posted September 5, 2023 Years ago a friend & myself replaced the sill channels on my 110CSW with 50x30x3mm rectangular box, we made access holes for the front bolts & sealed them with sealant & a grommet, rear we used dome plastic rectangular caps, B post is spot welded to the sill. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted September 5, 2023 Author Share Posted September 5, 2023 Thanks for the replays. There is not much left to measure exactly, but around 50x30 seems to be 😃 FridgeFreezer made it in 25. Does this mean, that there is space to make them bigger? Depending on the shoe, which connects to the bulkhead, are there bigger sizes possible? I know that safety in a car like a OneTen is academic, but since I like to play around and will have to do it anyway .... why not a little better than original? To bolt the pillars is a pretty nice solution as well, even with rivnuts in a box rail. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted September 5, 2023 Author Share Posted September 5, 2023 (edited) I found a pretty good article in the LRM with a lot of self explaining pictures. Part 1: https://www.landrovermonthly.co.uk/articles/how-to/defender-sills-b-posts-c-posts-removal/ Part 2: https://www.landrovermonthly.co.uk/articles/how-to/repair-defender-sills-and-posts/ Some pics tell me, that there needs to be an open profile to connect the sill to the bulkhead. How did you manage that with a box profile? This pic is from the LRM article, it points to the Adress of LRM Edited September 5, 2023 by Sigi_H Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 5, 2023 Share Posted September 5, 2023 It's been a while, it's hard to see exactly - if I'm in the garage I'll try and remember to get a better photo! Rock slider install: Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 5, 2023 Share Posted September 5, 2023 Looks like maybe just one bolt and done but I'm not 100% sure of that from the photos I have to hand. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted September 5, 2023 Author Share Posted September 5, 2023 Thanks a lot for the pics Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 5, 2023 Share Posted September 5, 2023 I took better photos but the truck's a bit muddy The far end under the back seat / tub: Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted September 6, 2023 Author Share Posted September 6, 2023 Thanks again. The pictures make the decission easier. One weak point seem to be the connection of the sill rail to the bulkhead if using a rectangular tube. But why not connect it as well to the main skrew of the bulkhead? This should make it a lot harder. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 6, 2023 Share Posted September 6, 2023 48 minutes ago, Sigi_H said: Thanks again. The pictures make the decission easier. One weak point seem to be the connection of the sill rail to the bulkhead if using a rectangular tube. I'm not ruling out the possibility that I put a threaded hole in that end of the tube where it covers the hole - it was a long time ago! Also the sills haven't moved or fallen off in the last ~15 years . Quote Link to comment Share on other sites More sharing options...
western Posted September 7, 2023 Share Posted September 7, 2023 On 9/5/2023 at 2:36 PM, Sigi_H said: I found a pretty good article in the LRM with a lot of self explaining pictures. Part 1: https://www.landrovermonthly.co.uk/articles/how-to/defender-sills-b-posts-c-posts-removal/ Part 2: https://www.landrovermonthly.co.uk/articles/how-to/repair-defender-sills-and-posts/ Some pics tell me, that there needs to be an open profile to connect the sill to the bulkhead. How did you manage that with a box profile? This pic is from the LRM article, it points to the Adress of LRM On mine we made a hole large enough to get the 2 nuts on their bolts & get a ring end of a spanner on the nuts, then closed with a suitable sized grommet & sealant Quote Link to comment Share on other sites More sharing options...
