Geojake Posted September 10, 2023 Share Posted September 10, 2023 I’m changing my lift pump on a disco 200tdi engine. The old one has a bent arm. Does this mean that I need to have a spacer for the new one, to prevent this from happening? When trial fitting, it doesn’t sit flush on the block. Photos below. Cheers Quote Link to comment Share on other sites More sharing options...
Geojake Posted September 10, 2023 Author Share Posted September 10, 2023 Fyi as far as I can tell, I have the factory spacer built into the block. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 10, 2023 Share Posted September 10, 2023 The spacer routine going around is a Fad imho, you'll alwas see an improvement when your fitting one with a new pump. to fit yours, rotate the engine so the cam lobe operating the pump is out the way. Quote Link to comment Share on other sites More sharing options...
Geojake Posted September 10, 2023 Author Share Posted September 10, 2023 2 hours ago, vulcan bomber said: The spacer routine going around is a Fad imho, you'll alwas see an improvement when your fitting one with a new pump. to fit yours, rotate the engine so the cam lobe operating the pump is out the way. Thanks for that @vulcan bomber, it went in. Although didn’t solve the running issues! 🙈🙈 the diagnosis continues… Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 10, 2023 Share Posted September 10, 2023 Mike says on his recent BritRest videos that he spent a lot of time trying to find out which pumps should have spacers and which not, and trying different combinations. He found the best result was to use no spacer but three gaskets to get the best positioning of the pump. He reckons the spacer is too thick, but that most pumps have too long an arm and that they are overstressed when fitted with one gasket. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 11, 2023 Share Posted September 11, 2023 15 hours ago, Snagger said: Mike says on his recent BritRest videos that he spent a lot of time trying to find out which pumps should have spacers and which not, and trying different combinations. He found the best result was to use no spacer but three gaskets to get the best positioning of the pump. He reckons the spacer is too thick, but that most pumps have too long an arm and that they are overstressed when fitted with one gasket. Sounds like it needs a thinner spacer - three gaskets sounds like a bodge to me. Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 11, 2023 Share Posted September 11, 2023 2 hours ago, FridgeFreezer said: Sounds like it needs a thinner spacer - three gaskets sounds like a bodge to me. It does - I can see them tearing or compressing and leaking, perhaps even allowing enough movement to shear the bolts. A thinner shim would be the ideal, or maybe the cam operating arm could be bent a little more to put less pressure on it? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 11, 2023 Share Posted September 11, 2023 I'm not familiar with how thick the spacer is, would likely be the work of moments to throw one in a mill or lathe and skim a bit off unless it's difficult to hold / too flimsy. Quote Link to comment Share on other sites More sharing options...
Geojake Posted September 11, 2023 Author Share Posted September 11, 2023 Yeah I saw Mike’s video. He says 2.6mm or something, whereas the spacer is 4 or 5mm so too much. Mine is on without any (also I bought a Delphi not a Blue box so doesn’t come with) as I have the spacer already built into the block as above. Let’s see how long it lasts, if it goes in 6 months then I know why! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 11, 2023 Share Posted September 11, 2023 My spacer is nearer to 10mm and definitely required as two pumps failed before I realised it was missing, not had a problem since. Not sure if there's one built into my block or not. Mike Quote Link to comment Share on other sites More sharing options...
Geojake Posted September 11, 2023 Author Share Posted September 11, 2023 3 minutes ago, miketomcat said: My spacer is nearer to 10mm and definitely required as two pumps failed before I realised it was missing, not had a problem since. Not sure if there's one built into my block or not. Mike Did you make this yourself or buy it Mike? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 11, 2023 Share Posted September 11, 2023 2 hours ago, FridgeFreezer said: I'm not familiar with how thick the spacer is, would likely be the work of moments to throw one in a mill or lathe and skim a bit off unless it's difficult to hold / too flimsy. Its not readily lathable, just wants laser cutting from the corect thickness material 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 11, 2023 Share Posted September 11, 2023 2 hours ago, Geojake said: Did you make this yourself or buy it Mike? It came with a pump. But that truck had one already so didn't use it. The pump I used on this truck didn't come with one but having had two fail I decided to use it. Mike Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 12, 2023 Share Posted September 12, 2023 12 hours ago, vulcan bomber said: Its not readily lathable, just wants laser cutting from the corect thickness material That would be the best solution. If you or Ed Parrot could knock out some batches, I’m sure they’d sell - Mike and most likely Charlie Emberton and Richard of Glencoyne Engineering would probably buy a batch. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 12, 2023 Share Posted September 12, 2023 3 hours ago, Snagger said: That would be the best solution. If you or Ed Parrot could knock out some batches, I’m sure they’d sell - Mike and most likely Charlie Emberton and Richard of Glencoyne Engineering would probably buy a batch. It's on my list for attention. 1 Quote Link to comment Share on other sites More sharing options...
